Old 06-03-2013, 05:48 PM   #1
6twenty5
6twenty5's Avatar
Throttle Linkage
Does anyone have any pics of the linkage on a 6cyl to SBC swap?
I am at a bit of a loss as to where to start.
1964 Chevrolet C-10 SWB
Fort Worth, TX
6twenty5 is offline   Reply With Quote
Old 06-03-2013, 08:58 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Throttle Linkage
Unless you have your heart set on mechanical linkage, you might want to consider swapping to a cable throttle. I switched mine to a 1971-72 model and it changed the entire personality of driving the truck. It is really smooth. Details of the installation are shown on my build thread starting around post #110:
http://67-72chevytrucks.com/vboard/s...=444502&page=5
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-03-2013, 09:47 PM   #3
66Submarine
66Submarine's Avatar
On all my stuff it's really easy. The rod itself that normally goes from the firewall to the bellcrank goes to the throttle on the carb instead. On my 2 barrel 283, to get full throttle travel I drilled a hole in the throttle closer to the pivot and added a ball joint. Screwed one in the hole in the crank on the firewall, and used an old adjustable rod I had laying around to link it all up. Works nicely, and it's super easy to do.
66Submarine is offline   Reply With Quote
Old 06-03-2013, 09:49 PM   #4
WhippinSaw
WhippinSaw's Avatar
here is some info on the mechanical linkage http://67-72chevytrucks.com/vboard/s...rottle+linkage
WhippinSaw is offline   Reply With Quote
Old 06-03-2013, 09:55 PM   #5
66Submarine
Here's a picture of mine. Not great, but you get the idea.
Old 06-04-2013, 09:52 AM   #6
1963c-10
1963c-10's Avatar
Why not just get a linkage from a sb truck and install? Only 2 bolts and about 10 min worth of work.
1964 Short bed trailer
Old 06-04-2013, 09:58 AM   #7
6twenty5
6twenty5's Avatar
That's what I had planned on doing but I can't find the linkage. The body shop lost all but the rod to the pedal and the rod just on the other side of the firewall.
Fort Worth, TX
Old 06-04-2013, 10:00 AM   #8
MikeN
MikeN's Avatar
This is reproduction linkage for a 67 Camaro with 396. One end threads into the other, so it's adjustable for length. Works great.
MikeN is offline   Reply With Quote
Old 06-04-2013, 10:10 AM   #9
1963c-10
1963c-10's Avatar
PM sent....I have a few people you can try.
Old 06-04-2013, 10:37 AM   #10
6twenty5
6twenty5's Avatar
Thanks, great info.
Fort Worth, TX
Old 06-04-2013, 10:37 AM   #11
6twenty5
6twenty5's Avatar
This rod connects to your factory linkage coming from the firewall?
Fort Worth, TX
Old 06-04-2013, 12:26 PM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
For about 20 years I just used a pair of rod ends and a length of ¼” all thread to connect the carb to the firewall pivot arm, and never had a problem. This shows the overall setup:
And this is the back half. Obviously I changed spring connections at some time:
These are the rod ends I used. The all thread came from a local hardware store:
http://www.summitracing.com/parts/mrg-3812g
Old 06-04-2013, 01:34 PM   #13
MikeN
MikeN's Avatar
Yes, exactly.
Old 06-04-2013, 02:01 PM   #14
gofastnut
gofastnut's Avatar
If you go the aftermarket route, Lokar has a couple of decent ones. If you're just after a cable, Mr Gasket makes a decent universal cable, my buddy used that one with good results.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
