Old 06-01-2013, 11:37 PM   #1
slam59
Preferred exhaust tail pipe location?
Getting ready to have my exhaust pipes moved to rear of truck. Currently I have turndowns right at center of truck about right behind where the seat is. Dual exhaust with flow masters so its pretty loud and getting annoying especially when idling. Was wondering where most of you here route yours at. My wife's 77 has them right behind the rear tires which is where I think I want to put mine. Where do some of you have yours located and why?
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
slam59 is offline   Reply With Quote
Old 06-02-2013, 12:22 AM   #2
GM-power
GM-power's Avatar
Re: Preferred exhaust tail pipe location?
I have duel straight pipes coming out the sides behind the wheels. Ive always perfered the look and I think you can hear it better than straight back under the bumper.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 06-02-2013, 12:34 AM   #3
slam59
Have any pics from the rear to see what it looks like?
1974 C10 swb 350
Old 06-02-2013, 12:48 AM   #4
Rufton
I switched from dual rear turn downs to straight out the back and the cabin is quieter. I think dual rear exit sounds best from behind; stereo effect. Sometimes I prefer look of side exit but not the mono sound.
Rufton is offline   Reply With Quote
Old 06-02-2013, 09:57 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
both of mine are out before the tires
79 straight out the side,78 out @45 bounces off the ground
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-02-2013, 06:48 PM   #6
cedens
cedens's Avatar
I always liked the looks of the duals coming out behind the rear wheel, almost like a pair of pistols being held by Yosemite Sam!
I can't comment on the noise, my 82 has had straight pipes for years, since the fiberglass burned out of the glass packs about 6 or 8 years ago.
Then again I sorta like the straight pipe roar, but I live way out of town with no noise ordinance, and there is no way I'll drown out my neighbor's factory stock and its 400 + CUIN race engine he tests up his long drive LOL.
cedens is offline   Reply With Quote
Old 06-02-2013, 07:50 PM   #7
dirt_migirt
I am gonna do headers back to mufflers and use turn downs and dump it at the rear end
dirt_migirt is offline   Reply With Quote
Old 06-02-2013, 09:24 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
i like that look too,i compare it too a dragon breathin fire lol in my case smoke
John
Old 06-02-2013, 09:36 PM   #9
cedens
cedens's Avatar
They come out at an angle with a slight pitch down, straight pipe, no fancy tips just grey tail pipe, someone however removed any other devices that could choke the engine down but yea on cool mornings it will breathe smoke like a dragon.
#lovelivinginthisstate
Old 06-02-2013, 09:46 PM   #10
Shyguy
Junior Member
Shyguy's Avatar
Here is how the exhaust pipes are ran out the back of a truck I bought a while back.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-02-2013, 09:51 PM   #11
cedens
cedens's Avatar
That would work unless you still have the spare underneath, but after ripping the spare tire carrier off about three times we built a rod that holds it down flat in the bed of the truck, farm engineering at its best.... if you can't afford it, find what you have and make something, so i believe my lock bar used to be a piece of sucker rod from an oil well.
Old 06-02-2013, 10:03 PM   #12
slam59
Just trying to make up my mind on where I want them. I know depending on whether they are behind rear wheels or straight outback it will have a different sound. I kinda like the look under rear bumper slightly turned down and just barely showing the tips. Decisions decisions
1974 C10 swb 350
Old 06-02-2013, 11:41 PM   #13
demok83
demok83's Avatar
I have mine coming straight out the back. I love that look, and I didn't want them getting all crapped up by junk coming off of my tires.
demok83 is offline   Reply With Quote
Old 06-03-2013, 12:03 AM   #14
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Here is my setup in my 79 SWB 4x4, had them come out behind the wheels, not a fan of straight out the back.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 06-03-2013, 01:17 AM   #15
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
I had mine coming straight out the back. The only complaint was hooking up my trailer to tow while the engine was idling.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 06-03-2013, 02:35 AM   #16
dieseldawg142
dieseldawg142's Avatar
behind the tires for me. trailer hitch is in the way, & like Big 10 says, your not gassing yourself hookin' up
dieseldawg142 is offline   Reply With Quote
Old 06-03-2013, 04:55 AM   #17
Remon.
Remon.'s Avatar
I also prefer to have a dual exhaust behind the rear axle. Best looks & sound combination, especially when you drive next to a wall or something
Remon. is offline   Reply With Quote
Old 06-03-2013, 09:23 AM   #18
Rufton
That looks good to me.
Old 06-03-2013, 09:41 AM   #19
cedens
cedens's Avatar
Now that brings back memories of my youth "cruising" downtown, letting the sound reverberate off the buildings.
Old 06-03-2013, 11:31 PM   #20
popsthebuilder
Mine turn down slightly just before the rear wheels. I think this is factory on the 73 camper specials because of the placement of the actual over cab campers. Not 100% but I love the look and sound. Factory pipes/ mufflers are actually pretty quiet.
popsthebuilder is offline   Reply With Quote
Old 06-05-2013, 05:08 PM   #21
cedens
cedens's Avatar
Okay went out to give mine the weekly fire-up and snapped a few pics, mostly to start a where to start sheet which i'll start up a new thread on later.
Old 06-06-2013, 08:46 PM   #22
bigd65
bigd65's Avatar
I have mine out the back but slash cut down behind the rear bumper so they don't show. When I get my truck back from paint, I take a pick of it but its pretty explanatory
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 06-06-2013, 11:57 PM   #23
bagged82
bagged82's Avatar
I just built these tonight on my air ride truck turned down in the corners
bagged82 is offline   Reply With Quote
Old 06-07-2013, 12:58 AM   #24
cedens
cedens's Avatar
Neat concept Bagged, too bad i dropped the 82 off at my muffler guy today, two new glass packs and a little bit of new pipe, hopefully he'll add more aluminum, and i promise not to pull out my bag of tricks to burn the glass out of the new packs
Other than that $100 for the set and a couple feet of new pipe, same guy who's done all the exhaust work on her.
Old 06-07-2013, 04:44 AM   #25
slam59
Well in the morning I'm taking it to my muffler guy to get mine extended from the center of truck with turndowns to probably right behind rear tires with chrome tips. Will take pics and post them. Also will film to hear difference
1974 C10 swb 350
