Old 06-10-2013, 09:57 AM   #1
CUSTOM/10
CUSTOM/10's Avatar
Trim hole locations ?
Does anyone have diagrams / measurement for all the trim hole locations ?
I have a 72 swb with all the trim, upper, lower side trim, tailgate trim with wide band, cab paint devider trim ( stud locations ) and badge locations for
Cheyenne & 8-350.
Any help would be great !
Thanks !!!
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 06-10-2013, 10:48 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Trim hole locations ?
Here are some:
http://outintheshop.com/faq/trim/trim.html
The factory assembly manual has all of them and is a good investment.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-10-2013, 12:47 PM   #3
CUSTOM/10
CUSTOM/10's Avatar
Thanks.... Leddzepp !!!
Does anyone have the rest, or a assembly manual ?
Gary
72 SWB 4x4
My 72 SWB Build
Old 06-11-2013, 12:03 AM   #4
GruntMoanCough
GruntMoanCough's Avatar
PM sent. Re: paint divider trim.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 06-11-2013, 02:27 PM   #5
mcbassin
Still Learning
mcbassin's Avatar
Thanks for the link,
Does anyone have the emblem placement locations for the fenders?
also, where is the dimension coming from on the vertical locations for the upper trim? is that from the top of the fender?
1.34"-1.23"1.16" etc,,,,
Old 06-11-2013, 03:05 PM   #6
Sklptrljay
Sklptrljay's Avatar
I just laid out my own trim, and if it comes out looking decent I'm going to start a thread with all my measurements and methods. I searched and searched on this site to find a step-by-step I couldn't find one, hopefully I can save people from the crap I went through.
Sklptrljay is offline   Reply With Quote
Old 06-11-2013, 04:16 PM   #7
camrycurt
camrycurt's Avatar
Here's a link to the complete set of trim hole locations and an explanation of the 30" line that the upper trim locations reference: http://67-72chevytrucks.com/vboard/s...d.php?t=221881
When I added my trim to a non-trim 1970 truck, I based all of the upper trim locations off of the piece that goes on the door. With the cutout for the door lock, that was the only piece of trim that had a definite location, so I fit that piece first over the door lock and under my mirror arms and then located all of the other upper trim pieces off of that one. I used painter's tape to line them up until they looked good and then marked the holes.
The spear points at the front were pretty easy because they come right off the door trim piece and point at the upper end of the radius on the fender around the headlights.
Just watch the alignment of the upper bedside pieces because the alignment from the factory has them starting in line with the trim from the doors but angling down to meet the top corner of the taillight trim.
If you tape everything up and then step back and compare it with some factory pics it's pretty easy to see if you're off anywhere. It's not too hard to get it all lined up.
Good luck!
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 06-12-2013, 09:38 AM   #8
CUSTOM/10
CUSTOM/10's Avatar
Thanks Curt, that's just what I needed.....
Thanks to everyone else that has helped out also !!!
Gary
Gary
72 SWB 4x4
My 72 SWB Build
