64 C10 longbed two or one piece axle with 383 stroker engine
HI
I have a 64 c10 longbed with a strong 383 stroker engine and th700r4 tranny. My original drive shaft set up is a two piece drive shaft with upper mount bearing. Now that I put in the th700 transmission my front drive shaft is to long. I have read a lot about one versus two piece drive shafts but I am still not sure what the best option will be. My upper mount center bearing is the weaker one and I have the thinner front drive shaft. My truck is lowered 4" in the back. Will a one piece axle work without interfering with the crossmember or should I stay with my two oiece acle and just shorten the front piece. I am a little worried about it because I have not got the heavy duty lower mounted support bearing and thicker front shaft. Any advice from you guys? Thanks a lot I live in the Netherlands so getting parts such as a bracket for a lower mount center bearing is very difficult.... |
![]() Join Date: Aug 2012
Re: 64 C10 longbed two or one piece axle with 383 stroker engine
Though I don't have an answer for you, I'm in kinda the same situation. I'm currently building a 66 C10 LWB and will be running a stout 383 with a T56 6 speed tranny.
In my research I've been told that the 2 piece driveshaft is actually stronger than a long single driveshaft due to the length. I guess it's the torsional twisting of the longer one that is the concern. As far as the bearing support, I'm interested to see some replies too. |
Does anybody know what the maximum outside diameter can be for a one piece driveshaft on a longbed 64 c10 and still have enough clearance with the crossmember? And what is the maximum amount you can lower a truck with a one piece axle?
Registered Loser
I don't have any problems with my 2 piece driveshaft and 383 stroker (405hp). My carrier bearing mounts on the bottom though.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
Problem is that my slip yoke has far too much play. And finding a replacement drive shaft here in the Netherlands is very difficult. That is why I was thinking about replacing the whole shaft for a one piece.
The overall length of my drive shaft would be 66". A 3.5" od driveshaft can have a maximum length of 65". The question is what the maximum outside diameter is a 64 longbed can have to still clear the crossmember.. |
![]() Join Date: Mar 2013
Have you looked online for some places to build you a custom drive shaft?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
No I went to my local shop. Building a one off with new slip yoke will get far to expensive. Around 750 euro, that is about 900$.
Posted via Mobile Device |
today I measured what clearance I would have between a 3.5" thick one piece driveshaft and my crossmember. Because the yoke on the diff is not centered the clearance between de driveshaft and crossmember on the right side is only 5/16" That's can not be enough....
#9 | |
![]() Quote:
Why can't you just shorten the tranny-end of your 2-piece shaft & use the bearing & slip-joint as is? Sam |
My slip yoke has far too much play to allow the shafts to be balanced out correctly..
60-66 Nut
I would stay with a 2 piece driveshaft in a long bed. Do you have wrecking yards that would have some GM trucks from in the 70's and 80's? You should be able to find a driveshaft(s) from one of those that can be made to work. You can typically have a driveshaft shortened much cheaper than having one lengthened, or a complete new one built. And while at it I would upgrade to the HD center support bearing.
I believe I have some fairly good stock HD driveshafts, but I imagine shipping to The Netherlands would be expensive.
