Old 06-18-2013, 08:11 PM   #1
JCampbell
Yet ANOTHER backspace question
Can't believe I can't get this into my head yet. Search results came up inconclusive.
20x8.5" rear wheel. Recommended backspace? Same as front: 5"?
[Not bagged, 6" drop in rear]
JCampbell is offline   Reply With Quote
Old 06-18-2013, 08:31 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Yet ANOTHER backspace question
No.
Most 10's require a 5.5" BS.
So that equals a 4" BS on a 8.5" wheel mounted on the back.
(remember the front track width is wider than the rear track width).
Break out a tape and verify this.
Keith
Convert to disc brakes.
Old 06-19-2013, 12:12 AM   #3
JCampbell
Sooo...if I went 8.5s all the way around, I'd have to get them in two different offsets (front and rear)?
Old 06-19-2013, 12:17 AM   #4
mgchevyparts
mgchevyparts's Avatar
Most wheels are cast so you won't have a choice of BS, cast wheels usually come one way, so which wheel are you looking at, and what is it's back space?
mgchevyparts is offline   Reply With Quote
Old 06-19-2013, 06:16 AM   #5
lolife99
lolife99's Avatar
yes.
Or run spacers on the rear.
That's why most people run 8's and 10's or 7's and 8's.
It help hides the wider front track width of these trucks.
Keith
Old 06-19-2013, 11:07 AM   #6
JCampbell
Gotcha. So I could go 5" BS all the way around and run a 1" spacer on the rear, correct?
Old 06-19-2013, 02:43 PM   #7
JCampbell
I really don't know why I find this such a hard concept to grasp...
I found a set of 20x8.5 w/ 4.5" of BS. Will this work for me. 4.5" will pull the wheel 1.2" to the *inside* versus a wheel w/ 5" of B.S., correct? So worst case, I could run a 1/2" spacer up front.
Old 06-19-2013, 05:14 PM   #8
lolife99
lolife99's Avatar
No.
BS is measure on the backside of the wheel.
Higher the "backspace number",... the more it will tuck under the fender.
5" backspace wheel will tuck 1/2" more than a 4.5" backspace wheel.
(as long as the wheels are the same width).
Keith
Old 06-19-2013, 06:59 PM   #9
JCampbell
So is 4.5 a no-go on a 5/7 drop then?
Old 06-19-2013, 08:15 PM   #10
lolife99
lolife99's Avatar
I my opinion you need a 5.25" bs on a 8.5" wheel up front.
Keith
Old 06-19-2013, 09:28 PM   #11
slugish
Slugish
x2 with low life
got 9.5 rims on back with 4 in B.S.bout as much as can work ---> close but ok
got 8 in rims on front with 5.5 b s -> could have gone with 5 in or possibly 4.5
Im running 17 in rims w/ a 5.5 - 7 drop .
hope this helps > think low life is right on the mark
slugish is offline   Reply With Quote
Old 06-20-2013, 06:24 AM   #12
wraprail
wraprail's Avatar
.....High Positive Offset____________________________High Negative Offset (aka "reversed")
wraprail is offline   Reply With Quote
