Installing "Custom" cab moldings
So I bought these cab moldings for my 65 longbed but not quite sure how I want to go about putting them on just yet. Any ideas?? I know I've really only got about 2 choices, glue it or drill it on there. Just curious what you guys have done and what's worked and hasn't.
![]() Join Date: Sep 2011
Re: Installing "Custom" cab moldings
You should drill pilot holes for the screws and then pick up a set of replacement screws from any of the classic truck supply shops (LMC, Classic Parts, Brothers). They all have the screws, they're stainless, and very inexpensive.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
I used 3M double sided tape.
Its somewhat of a tight fit where the molding meets the edge of the door. Would tape make it stick out too far? or would the heads of the screws stick out too far? Do you think this could be a different problem related to the position of the door?
I used the double sided tape on the leading edge and there's no impact with the door.
This solution worked for me as I didn't want to drill holes in my cab. |
![]() Join Date: Mar 2013
Easiest thing would be double side tape...but I would screw it on just for the fact of knowing that they won't fly or fall off.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Id go with the factory option and get the 4 screws that they each take.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
And use double sided tape at the upper, outer corners to secure the top portion if you don't have the brackets. Stack up the tape in a 2 inch section
GOD BLESS AMERICA! |
Does anyone have a link to a site that sells the hardware? I just checked classic parts an they don't sell just the screws.
Tags |
1965 c10, advice, cab trim, custom, molding |
