lockers
anyone have any experience with the powertrax lockers? I am looking at replacing the open diff in my truck and this seems to be an affordable option. But i am concerned with longevity and if they hold up well.. any input is appreciated!
Re: lockers
I have one in my truck, its held up to a blown sbc that I used to run, now a tpi mill. You feel it ratchet in a turn, but that's about it. Nice little affordable device. Ive had it in my for about 6years.
Re: lockers
What's your current gearing? Tire size? How much power is you engine making do you think?
These aren't good for tires over '30in and wide tires as well. Or big hp. Basically it's not a good idea for track or heavy off road or high stress situations with wide or sticky tires. Offroad guys like em take a look at what they seem to concur on for a Long lasting design. Lunchbox lockers have been around for a while but small differences between them all. Some are quiet and some are aggressive and noisy Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Re: lockers
Have you ever ran one INSIDIOUS? I have and do... I know a few people who have run them off road as well with no problems. I'm not saying you are wrong, but I'm not sure where you get your information from. Heck, my best friend used to run a mini spool on the street... would I do that? No... these at least allow the wheels to differentiate in a turn which is safer than a spool or mini spool. How much power was I making with my blown SBC? Your guess is as good as mine....12lbs boost at the time with two fat black strips down the tarmac. Its held up fine. My diameter is 29", call it 30" with my 20" TTII'S. These are an affordable and durable way to get rid of a peg leg. First hand experience here...
Re: lockers
I'm interested in them as well, but being up here in Canada, I'm concerned about winter driving with one.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Re: lockers
i was looking into one of these for my dually
"DON'T TOUCH THE TRIM!!"-Early Kyler |
Re: lockers
never had a powertrax (i'm running a detroit), but my friend has one in his TJ. very good off-road, but on road is not that great. always sounds like the diff is coming apart (ratcheting around corners) & quite often his jeep literally jumps around corners as it locks/unlocks. he also does not like driving it in the snow (unless he's going strait). a short wheelbase & 33's maybe why it acts so squirrely. he is currently saving his money for an ARB
Re: lockers
The ratcheting is noticeable on a slow sharp turn, probably not so much in a heavier truck. My truck doesn't jump around turns, just ratchet. I think the wheel base and weight play a big role.
#9 | |
Re: lockers
Re: lockers
I agree with your statement that its only as strong as the case that its in, but that applies to any unit in any case. Torque breaks parts, not horsepower. Boost isn't gentle on anything be it a roots style blower or turbocharger. Naturally aspirated or boosted, 500hp and 500ft.lbs of torque is 500hp and 500ft.lbs of torque. I've had a potent small block in mine and I didn't scatter anything. I run 1350 U joints and a 3.5" driveline now and I think with slicks or a sticky tire the first problem he would encounter is the stock 1310 U joints on these trucks fragging and dropping the driveline. Ten and Twelve bolt cases are pretty strong.
#11 | |
Re: lockers
we always told buddy to go with a limited for his jeep, his daily, but nope, he wanted a locker, it's a good locker, but not for how he drives it. still wants a locker-hence saving for an arb |
Re: lockers
I installed the Powertrax No-slip in my '87 K20. Auto trans, 4.10 gears, 265/75R16 tires.
I really like the powertrax. The no-slip is much more steetable than the Lock-rite, which is more off road oriented. I have had not issues at all with mine.
'99 K1500 Tahoe, 2dr, barn doors - 350/ 4L60E, 3.73 '01 K2500HD Silverado Ext Cab - 496/ Allison, 4.10 |
Re: lockers
Thanks for the input guys. My truck will live 80% of its life driving 60 miles to and from work with maybe the once a month or every other month it will see the track just for fun. Currently I have 29" tall tires and might go a little shorter next time around. I have a clutched unit from a 70's camaro but the cost of axles, bearings, a rebuilt kit is damn near twice the cost of this unit and it will be done. The rear end is 1000 mile fresh with new bearings everywhere and new 3.08 gears. I plan to do a set of 3.42 gears at the same time. Seems this might be just the trick for me. If I end up not liking it then I'm sure it will be easy to sell and just suck up the price of axles, etc..
Posted via Mobile Device |
Re: lockers
Oh and I live in Texas so we might see snow for a day each year but otherwise it's just a little rain and dry roads. My main concern is longevity on the unit and if the ratcheting is loud/obnoxious for a daily.
#15 |
Re: lockers
I have ran lockers in all my 4x4's . You rarely ever hear them . I run a 400hp 520lbs torque 454 and currently have a Detroit locker in a Dana 70. No problems . I run a tru trac up front in a Dana 60 . A locker, in my opinion is the single best mod for a truck. I would never run without one.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
#16 | |
Re: lockers
I was thinking of getting one to try out in my stepside project. Posted via Mobile Device
#17 | |
Re: lockers
#18 |
Re: lockers
[QUOTE=dieseldawg142;6133191]they sure do. my '71 jimmy was always chirping the tires on corners (detroit) & was a handful in the snow (39.5's didn't help), my '77 camper special would only do it on sharp, hard throttle corners (again detroit), slightly better in the snow, & you never notice the detroit in my crew unless you HAMMER the throttle on a corner (doesn't turn sharp enough to notice anything else). only thing in the crew is a light clunk when shifting D to R.
My 86 had a Detroit in it when I first got the truck.It opened up my eyes a couple times in the snow...coming into a 90 deg corner a bit too hot & really worn front tires = right into the ditch,luckily the Detroit helped get out too!! You could hear it ratchet on the pavement when turning,but worked great otherwise.Piled up a pinion bearing,so I swapped in an open diff for now til I get the other rebuilt. Posted via Mobile Device
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" ![]() |
#19 | |
Re: lockers
#20 |
Re: lockers
From personal experience I like the ARB air lockers.
Again from personal experience forget all about Eaton or Auburn Gear. Again from personal experience forget about limited slip or posi-traction as doing anything at all after 1 months time. Again from personal experience there is nothing on planet earth that hits likes boost from a supercharger down low.Turbos kick in blowers smash your eyes into the back of your head. |
#21 |
Re: lockers
as a former jeep guy... yeah I know... but anyhow. 350 tuned port,700 r 4 lock right's front and rear ( lunchbox locker's) 33 x 12.50 tires... the lockers held just fine. I did break one cross pin, and several axles, but I was in the rocks playing and got what I deserved.. but the lil lockers held just fine and they shipped me a new cross pin when I called, so customer service was great. they held up to me and some small horsepower / torque off good tires on rocks, id say you'll be fine on the street, that being said, they are lockers. they have poor road mannerisms. they will rachet, click, jerk when turning ( and maybe even after the turn if they haven't meshed back together. they WILL eat your tires. they can be a blessing and a hinderence in winter driving. ( jeeps are short wheel based and like to change ends on slick roads unless your in 4 wheel). but true posi, gets good traction. if shes going in a straight line that is...
#22 | |
Re: lockers
![]() If you look at gearing in Jeg's or even Summit you will notice they specify street or drag. The difference between street and drag gears is the hardness of the gears themselves. Drag gears are softer and designed to take some of the shock out of the drive line, therefore not recommended for the street and longevity. Is a Powertrax bullet proof, no. Will it work and work well? Yes. Powertrax recommends a hardened shaft to prevent cross shaft failures. I think if you give it a try you will like it for the traction, ease of installation, low cost and durability. |
#23 | |
Re: lockers
thanks guys! |
