Old 07-07-2013, 08:49 PM   #1
sleepertruck72
sleepertruck72's Avatar
Question Finding TDC using a piston stop
I need to stab my distributor back in. Long story but I removed it and probably didn't have to. Do I set the depth of the threaded rod on the piston stop to the same depth as the spark plug ? I'm going to go off the balancer if possible, it is hard to see since I installed a serpentine belt and the brackets are in the way...Any input is appreciated. Thanks
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 07-07-2013, 09:07 PM   #2
GRX
GRX's Avatar
Re: Finding TDC using a piston stop
I don't bother with a piston stop. Just a pencil in the spark plug hole while watching the rockers to be sure I'm on the base circle of the cam.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 07-07-2013, 09:10 PM   #3
Toxic Orange
Toxic Orange's Avatar
Check out this youtube video its the method I used. Can also help you confirm your timing line is still in the right spot and your balancer is not twisted.
Toxic Orange is offline   Reply With Quote
Old 07-07-2013, 10:42 PM   #4
72 K20
72 K20's Avatar
I use a TDC whistle that goes in the #1 spark plug hole. As you turn it over it will whistle on the compression stroke, then watch the balancer to get to TDC. This will get you close enough to drop in the distributor.
72 K20 is offline   Reply With Quote
Old 07-08-2013, 07:50 AM   #5
MARKDTN
I use a piece of paper towel in the plug hole. When you hit TDC on the compression stroke it will pop out.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-08-2013, 08:23 AM   #6
geezer#99
geezer#99's Avatar
X2
I've used a whistle I made out of an old sparkplug. Broke off the porcelain and drilled an 1/8" hole in the centre.
Old 07-08-2013, 09:32 AM   #7
volksworld
if you cant see the damper well enough to find tdc how are you gonna time it ?
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 07-08-2013, 04:57 PM   #8
sleepertruck72
I can see it, its just you have to look at the right angle... I'll have someone to help me turn the distributor while I aim the timing gun... my main concern is the length of the piston stop. I'll try it the length of the spark plug or a hair longer ?
72 C20 Longbed
05 1500 Z71
Old 07-08-2013, 06:08 PM   #9
geezer#99
geezer#99's Avatar
Go longer on the piston stop. Turn it by hand of course. Do not use the starter to turn it over!
Going the length of the plug won't do it.
Bring it around till it touches, mark the balancer, turn it back around the other way, mark the balancer. Right exactly between those 2 marks is TDC. Mark it, pull out the stop, turn the crank to your mark and see where your mark shows on the timing tab.
Old 07-08-2013, 06:35 PM   #10
JointTech
JointTech's Avatar
i got a thing with a spring on it and a rod that goes up and down. heres my build thread post about it.
http://67-72chevytrucks.com/vboard/s...8&postcount=47
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 07-08-2013, 07:24 PM   #11
sleepertruck72
Thanks for all the input...
I will get this done this week sometime. I appreciate ALL the input.
72 C20 Longbed
05 1500 Z71
