Old 07-16-2013, 11:20 PM   #1
solidaxel
solidaxel's Avatar
Dog House removal on a 78 SWB
I am starting a tare down on my 78, and are there any tricks to remove the sheet metal in as few pieces as possible.
Do I need to remove the front bumper?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-17-2013, 12:09 AM   #2
Rubble
Re: Dog House removal on a 78 SWB
This is how I usually do it,others might be different.Pull the bumper,makes it easier to get at the rad support mounting bolts,pull rad,& hood.I pull the whole front clip as one piece,there are 2 bolts on upper fender at rear.These are visible when door is opened,there are 2 more inside wheel well & one at rear of fender along the bottom inside.Undo all wiring from headlights,clearance lamps & any other assorted wires.It sounds worse than it is,I can usually pull the whole clip in an hour or so by myself.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 07-17-2013, 12:14 AM   #3
solidaxel
solidaxel's Avatar
That is what I wanted to hear.........................one hour, at my age that means one day!!
LS 3 4L70E
Old 07-17-2013, 02:28 PM   #4
Rubble
That's if everything goes good& I don't get distracted.....I get distracted easy!!lol... The worst part is usually pulling the bumper off,rusted bolts can be a pain.That's when the grinder comes out..I have a overhead crane in the shop,so it makes it easy to pull the complete clip this way too...
Old 07-17-2013, 03:59 PM   #5
solidaxel
solidaxel's Avatar
This is So Arizona, you only have to break the nut loose and remove them with your fingers!!
LS 3 4L70E
Old 07-17-2013, 08:13 PM   #6
Rubble
[QUOTE=solidaxel;6177587]This is So Arizona, you only have to break the nut loose and remove them with your fingers!!
That would be a nice change alright,but no challenge then eh!!!!
Old 07-18-2013, 01:31 AM   #7
solidaxel
solidaxel's Avatar
[quote=Rubble;6177982]
The challenge is remembering where I put the hardware when it goes back together!
LS 3 4L70E
Old 07-18-2013, 09:39 AM   #8
Rubble
I used to just throw all the hardware in a coffee can,now I am starting to label them.It makes it a lot easier when looking for specific bolts or screws.I have one project that's been going on 8+ years now & still not done,that one is gonna be some head scratching!!
Old 08-05-2013, 03:08 PM   #9
solidaxel
solidaxel's Avatar
.... What about the hood latch that is inside the cab, do I just un-hook it at the latch?
Finally had enough time and energy to tackle this engine swap!
Stay tuned for more questions and solutions
LS 3 4L70E
Old 08-05-2013, 07:38 PM   #10
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
yeah, just unhook it at the latch, you may have to remove the grille to get to it.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 08-05-2013, 10:06 PM   #11
solidaxel
solidaxel's Avatar
Thanks got it !!
Fishing it back in is going to be fun !!
LS 3 4L70E
