Old 08-17-2013, 09:27 AM   #1
slugger824
1962 gmc 4x4 front drum to disc conversion?
Looking to see if there is any previous threads concerning changing the front drum system to disc on a 62 gmc 4x4 with dana axle.
slugger824 is offline   Reply With Quote
Old 08-17-2013, 10:20 AM   #2
63burban
Chevy addict
Re: 1962 gmc 4x4 front drum to disc conversion?
Install later model axles, the old axles are not worth the time to mess with them
63burban is offline   Reply With Quote
Old 08-17-2013, 12:56 PM   #3
61K10
61K10's Avatar
somebody on here did it, don't remember who. they had to machine some parts to make it work.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-17-2013, 01:09 PM   #4
'63GENIII
'63GENIII's Avatar
It was JPBrecheisen and the post is on page 4 of the 4x4 section "1962 GMC Front axle With Disc Brakes" . It looks like a lot of work but it came out looking great! Good read.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-17-2013, 07:37 PM   #5
Brad54
Brad54's Avatar
Seems like it'd be easier to go through the junkyard and find Dana 44 front axle out of a Chevy, Dodge, Jeep or Ford, find the right width and move the spring mounting perches.
The Dana 44 is the most common axle assembly in America, and has been in continuous use since the early '50s.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 08-18-2013, 12:53 AM   #6
Captainfab
60-66 Nut
In my opinion, it would be much easier to find a '70-'79 Dana 44 or a '80-'91 8.5 10 bolt that matches the gear ratio you need and just change the entire differential.
Old 08-18-2013, 12:27 PM   #7
61K10
61K10's Avatar
he probably has 3.90 rear gears in the rear and 3.92 in front. I don't thank they made an open knuckle with these gears. you would have to change the ring & pinion if the 3.92 is available, or change both ft and rear axle's. I am going to run drums with a hydro-vac from a 3/4-1 ton. we will see-----------just remembered it's a GMC which has a dana rear?? was thinking about a chevy HO. what ratio did the gmc come with? same r&p ft and rear (size)?
1961 chevy K10
