Old 08-14-2013, 12:43 PM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Rear axle questions
I hope someone on here, smarter than me, can clear this up for me. Are the axle shafts for a '70 (6 bolt) and a '71 (5 bolt) the same length? Are both sides the same length? Can the backing plate and brakes from a '70 be used with the '71 drums? Any input will be appreciated.
TobyArnot is offline   Reply With Quote
Old 08-14-2013, 12:47 PM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Rear axle questions
The 71's axles are longer but the backing plates are the same I think. JEGS catalog has the lengths listed for the axles.
And the length is the same side to side.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 08-14-2013, 01:00 PM   #3
TobyArnot
TobyArnot's Avatar
So the '71 axles won't work in a '70 housing?
Old 08-14-2013, 01:03 PM   #4
russgoodman
russgoodman's Avatar
From what Ive read, yes and no. Apparently they used the narrow and wide rear in 1970. So you will have to measure how wide your rear axle is. If its the wide axle like they used in 71-72, you should be able to use those 5 lug axles. If its narrow like my 1969 is, spend the money on the Moser's.
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554
2008 GMC Sierra Denali - 6.2L AWD - my daily
2011 Ford Flex Limited - Ecoboost AWD - wife's daily
1987 Buick Regal Turbo T - 63K miles - Strip/Street car
1965 Ford Mustang Coupe - 289, c4, 53K miles
russgoodman is offline   Reply With Quote
Old 08-14-2013, 01:33 PM   #5
tlcrz1972
tlcrz1972's Avatar
71-2 axles are slightly longer, but will interchange with no problem. I've done it on a '66 but I also used the backing plates and all the brake components to guarantee no problems.
tlcrz1972 is offline   Reply With Quote
Old 08-14-2013, 02:43 PM   #6
uncle
If both housings measure aprox 57" from back of backing plate to same then they will work. Done it many times.
uncle is offline   Reply With Quote
