Door Speakers vs Kick Panel Speakers - Pics Welcomed
I currently have speakers behind the seat and I'm deciding if I want to put in kick panel speakers or install round speakers into the doors below the door panels. What your opinion/preference ? Maybe there is a better solution for front speakers that you have come across? I am ears...
Thanks KellerMac
Texas - Don't Let The Size Scare You! Last edited by KellerMAC; 09-20-2013 at 02:49 PM. |
![]() Join Date: Sep 2013
Re: Door Speakers vs Kick Panel Speakers - Pics Welcomed
I have the Kick pane speakers from LMC, I really like them, the only complaint it crowds my Door's Rubber seal and tries to push it out of place. but besides that I am Satisfied.
Hope, Faith and Strength
**Deestrong** |
#3 | |
![]() Join Date: Jul 2013
When I had my '69 I had 6x9's in the doors. I did have foam covers over them to protect from rain/dripping water.
I'm not a fan of cutting holes in the doors, but we do have little options especially if you still have the gas tank in the cab. 6x9's fit well below the door panel and can be made to look nice/professional. I don't know if I like the kick panel speaker idea as it seems to crowd the E-brake pedal and the dimmer switch, but I don't have them. I'll be following this post to see what others think
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
I'm interested too, keep it going!
What about that headliner with all the speakers built in LMC came up with? |
Moderator
![]() Join Date: May 2007
I had kick panels in my old truck. They needed a little trimming with a dremel tool to fit, but other than that no complaints.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
![]() Join Date: Jun 2012
Don't cut holes in the doors! ! If you do, you ruined the doors and the "sell it value" will be the same!
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
Petroleum User
Not in the doors unless the hole is already cut.
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
Here are my Kick Panels
**Deestrong** |
![]() Here is one of mine. I made the "enclosure" out of a t shifty and fiberglass Posted via Mobile Device |
![]() Posted via Mobile Device |
Any pics of the DS. I'm wandering how these kick panel type interfere with the parking brake and dimmer
![]() Join Date: Apr 2013
I installed some 3.5" speakers in the far outer ends of the dash and they fit perfectly, and sound great.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
#15 |
I have the Classic Industries kick panels that came loaded with 6.5 inch Pioneer 2-ways. Just fitted them yesterday, all I did was mold them to fit with a heat gun. The driver's side is really close to the parking brake pedal, and I will probably bend the pedal about 1/4 inch for better clearance. The dimmer switch had to move to the right about 3 inches as well to be usable. Even with those issues I still like them.
1990 Suburban Silverado 350, SM465 and 35" tires |
