Old 09-20-2013, 10:48 PM   #1
doublearrow
relay? switch?
I have a 1987 silverado and i recently put all new ac components in under the hood. Its been running great. But i havent been using it the last couple of weeks due to cooler temps amd i kept hearing a thunk at stop signs or low speeds. Turns on its my ac compressor kicking on even while every switch is in the off position. I looked for a relay to the ac system that could possibly be stuck. All i found was the fuse. Is there a relay or something else i should look for? The defrost is off ac off fan off its all off. Is it supposed to run? Thanks for any advice in advance.
doublearrow is offline   Reply With Quote
