bedchop
Ok I purchased a extra frame for my 63 stepside to chop into a shortbed. I found awesome link explaining exactly how to chop the frame. With that said anybody have a link or can post a write up on exactly where and how to chop the bedsides and the "step"?
Re: bedchop
You might try and find a stepside bed. If I remember right they are the same from the late 50's to the mid 80's.
63 short fleet Patina build http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one. |
Re: bedchop
Step side beds from 2nd design 55 to 66 are the same.
Re: bedchop
Thanks man. I'm really trying to go low buck on this thing. Soni really want to use what I have. But I will look around and see. The only difference on the beds are the bedsides correct and steps correct? The fenders will be the same?
Posted via Mobile Device |
Senior Car Nut
![]() Join Date: Jan 2008
Re: bedchop
the only shortening to the frame happens ahead of the rear axle, correct? (actually in front of the trailing arm cross member) if so, only a 12" section from the front portion of the bedsides and out of the middle of the steps should be required.
Larry |
Re: bedchop
No I do believe you also chop 8" off the rear. Also i cant find the damn link but i read that on a stepside you cut the bed differently than the fleetside sonething like 15" frint 5" rear. I'm thinking I may just buy new short steps and then cut the bedsides.
Re: bedchop
I chopped my long fleet down to a short fleet. 12" between the cab and trailing arm crossmember and 8" off the back. Do a search, there is a ton of information on it.
Good luck
http://67-72chevytrucks.com/vboard/s...d.php?t=742865 66 SWB, C4 Dropmember timmytimm3 on IG "If you don't have time to do it right the first time, when will you?" -Dad |
Re: bedchop
Yeah, the bedsides are shorter and the steps are shorter. All the other longbed parts will work for a shortbed conversion. And correct that the late 55-66 beds are the same, although most of the bed components are correct and interchangeable from 55-87, although big differences are the fenders and taillights.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#9 | |
Senior Car Nut
Re: bedchop
check this link, it has a board lengths chart and a diagram, might give you an idea: http://www.gmcpauls.com/47-72_BedWood_Info.htm according to the chart the difference in wood length is just shy of 20 inches. if you take 12 off the front that leaves you with the 8 that you were thinking and timmytimm did to his fleet
Larry Last edited by fleetsidelarry; 09-24-2013 at 08:22 AM. |
