![]() Join Date: Nov 2012
Piece of junk LMC sending unit
The fuel sending unit I bought stopped working right after installation. The float flooded I guess. Annoying.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
Re: Piece of junk LMC sending unit
I had the same problem. I guess it wasn't a good soldering job. I called and they sent me a new float with no problems. I guess its a common complaint.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
![]() Join Date: Oct 2009
nice they sent another one, but... lotsa work to install a piece of junk. anyone know of a more reliable supplier, or do they all come from the same float factory in china?
Sisyphus was my mentor!
![]() Join Date: Sep 2002
I had same problem. Ordered this off if eBay:
http://bit.ly/1bdqc2G & & it worked awesome. It's the exact same size as the factory float. Posted via Mobile Device
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
If that link doesn't work, just search this item #: 190911122317
I called LMC today and they agreed to send me a new float . I asked them what was I going to do if that float also sank like the previous one did . They told me they could not guarantee that the new one would not sink as well . So I told them I could not guarantee that I could use this kind of junk . When the new float arrives I am going to immerse it in liquid for several days before installation and make sure it does not also fill up and sink. By doing it this way I can avoid having to take the sending unit out of the gas tank again if this float is also bad .
I've had good luck (so far) with the fuel sending unit for my '72 that I ordered back in May from LMC. I have seen the issue you describe with other units - my buddy's had to replace several units in his 81 Ranger, and they always seem to separate at the solder joints. It sucks that quality parts are so hard to find these days - I'll pay extra for better stuff.
