Old 10-07-2013, 04:14 PM   #1
Squareforceone
Squareforceone's Avatar
Firewall seam sealer.
hey, i'm in the middle of swapping engines in my 84 and want to clean up the firewall a bit. I am however not stripping everything off it just some of the easier things and touching up with some rattle cans. I do however have some minor rust that i want to address while the engine is out. I think i need to strip a lot of the old sealer as i feel it's probably contributing to the rust issue.. I'm wodering what's the best way to strip it wire brush on a grinder? I'm also wondering what would make a good replacement seal on the cheap. I'm on a budget right now so i'm not looking for expensive eastwood seam sealer or anything.
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 10-07-2013, 04:45 PM   #2
dieseldawg142
dieseldawg142's Avatar
Re: Firewall seam sealer.
wire wheel & grinder, scrapers, pointed screwdrivers, whatever will work
for a good sealer, use urethane based. much better than solvent base, will stay on better & pliable way longer.
i just did the entire cab on my crew, used this stuff, 'bout $10 a tube. i primed everything before i sealed it
http://www.proformproducts.com/en/pr...32&category=24
dieseldawg142 is offline   Reply With Quote
Old 10-07-2013, 08:35 PM   #3
bigd65
bigd65's Avatar
Take it from me, do that right the first time. Get it all out and use the good seam sealer or you WILL regret it.... The 82 I flipped was rusted pretty bad. Was repaired with fiberglass and then seam sealer and then that flex seal, fill all the low cavities
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
