Old 11-13-2013, 12:54 PM   #1
locoluis30
Post your aluminum radiator set up!
Want to see some ideas on different set ups using stock or other brackets.Custom plastic/aluminum shrouds and electric single /dual set up or engine fan driven .
locoluis30 is offline   Reply With Quote
Old 11-13-2013, 12:56 PM   #2
locoluis30
Re: Post your aluminum radiator set up!
Engine fan driven set up!!!!
Old 11-13-2013, 12:59 PM   #3
locoluis30
Anyone
Old 11-13-2013, 02:30 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I run dual LS Camaro fans on my 454 two row radiator. It's busted right now. I hope to buy a new one this weekend or in two weeks. The stock shroud covers most of the radiator. When I install the new radiator, I'll use an extra panel and cover the bottom. It needs to pull more air through the radiator for A/C cooling. I'm also closing the gap between the radiator and condensor.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 11-13-2013, 03:25 PM   #5
locoluis30
Cool I read that you run 308 gears. What is your opinion on 373s over the stock 273?
Old 11-13-2013, 03:37 PM   #6
Jabes1
Jabes1's Avatar
Champion Radiator with Windstar dual fans... performance and cost effective.
Welcome to my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=574370
Jabes1 is offline   Reply With Quote
Old 11-13-2013, 05:01 PM   #7
gchemist
gchemist's Avatar
The 3.08 gears are okay for driving. Truck runs 255/60R15 tires. It's a small tire for a truck. Still it turns only 1950 RPMs at 70 MPH with a 700R4. Best milage recorded is 18.5 MPG!! Not even new trucks can pull that off.
I onced towed the same trailer with both my Jimmy (4.3L/3.42 gears) and my truck (5.7L/3.08 gears). The Jimmy towed way better with a smaller engine and larger tires. Gears are great. If you plan to run at minimum a 28" tire or larger with a 700R4, 3.73 gears are ideal.
Old 11-13-2013, 08:13 PM   #8
CHROMAHOLIC
CHROMAHOLIC's Avatar
CHROMAHOLIC is offline   Reply With Quote
Old 11-13-2013, 09:57 PM   #9
nekkidhillbilly
i dont want to be that guy but the 01 had pulled 23 mpg once and its 4wd.
nekkidhillbilly is offline   Reply With Quote
