Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-27-2014, 07:32 PM   #1
Super73
Super73's Avatar
Eagle Field Drags this weekend
http://eaglefielddrags.com/
Here is the link.. Super cool event at an old WW2 air base. Not track prep, 1/8 mile arm drop with no clocks.
I am making a few suspension changes to hopefully make the truck work better out there.
Put the 125lb tail gate back on
Lowered the rear 2 1/2"
Putting in a either a 100lb or 110lb spring in the rear with a 1" spacer (which ever will fit right) currently a 130lb
Set the instant center longer and lower (70/2 instead of 57/5) to hopefully help transfer better
Will be softening up the bound of the rear shocks
Will be running on motor only. Might take some timing out of the motor for the initial hit. Should be fun!!
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-28-2014, 08:46 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Eagle Field Drags this weekend
I'm wishing I can go. Maybe as a spectator.
Old 01-28-2014, 11:09 PM   #3
softballnrd27
Always a work in progress
softballnrd27's Avatar
If only it wasn't 6 hours away!! I'm in SoCal until the end of March
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 01-29-2014, 03:30 PM   #4
john@thepier
john@thepier's Avatar
Looks like a real fun time.
john@thepier is offline   Reply With Quote
Old 01-31-2014, 11:54 AM   #5
team39763
You know we wanna see some videos man or atleast some pictures of your truck in action out there. Good luck.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 01-31-2014, 03:44 PM   #6
Super73
Super73's Avatar
Sounds like I will be going to Sacramento instead. Will try for some video.
