Old 11-03-2013, 09:04 PM   #1
Mack B
Mack B's Avatar
CCP tubular control arms and airbag questions
Anyone using these arms? I've been reading and am interested because of the increased ground clearance over stock and the camber benefits. I saw in another area of the forum a 2600 airbag will not fit. Will the ride be very harsh with a smaller bag? If say I used a 2500 airbag would I have significantly less lift than the larger bag? Thank you for your help.
http://www.classicperform.com/Store/...TCA-LKB481.htm
Mack B is offline   Reply With Quote
Old 11-05-2013, 10:21 PM   #2
Mack B
Mack B's Avatar
Re: CCP tubular control arms and airbag questions
Anyone?
Old 11-07-2013, 01:30 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
I run the CPP LCA with an Air Slam Specialties spring…
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-07-2013, 08:13 PM   #4
Mack B
Mack B's Avatar
Looks great! Is it very hash at ride height?
