Old 09-12-2016, 03:20 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
Hazard lights?
Rewired my truck with painless and the turn signals worked but no hazards, I replaced the switch and still no hazard lights. The fuse is good and all the other lights work fine. Any ideas?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 09-12-2016, 03:32 PM   #2
Jarvis-69 GMC 1500CK
Re: Hazard lights?
As far as I can tell (I do not know much) it has a different flasher unit for 4 ways, try making sure using a power probe the flasher socket is doing something, from there you can make your way to the switch.
I don't think the issue would be past the fuse box, they all use the same wires anyways.
I was doing some troubleshooting because nothing in my truck works the way it is supposed to (actually going to be getting a painless harness next year out of frustration).
I found when I took the bigger flasher unit out the 4 ways would stop all together, so I assume that is a flasher for the 4 ways.
Take my advise with a grain of salt though, this is just what I assume, and assuming makes an ass out of you and me!
Jarvis-69 GMC 1500CK is offline   Reply With Quote
Old 09-12-2016, 05:16 PM   #3
Wildstreak
Wildstreak's Avatar
Re: Hazard lights?
There was a second flasher fuse I was missing in the top left that I didnt think about. Thanks man all working now!
57 chevy 4x4
68 burb 2wd:
Old 09-12-2016, 05:20 PM   #4
Re: Hazard lights?
yay! first issue actually solved and it is not even on my truck glad I could help.
How easy are the painless harness's by the way?
