Old 12-07-2013, 08:41 PM   #1
blastboy
Frame paint
Hello everyone, I've been lurking for a long time so I figured It was time to ask a question. What kind of paint do you use to paint the frame back to the factory satin black? Thanks in advanced-JP
blastboy is offline   Reply With Quote
Old 12-07-2013, 09:00 PM   #2
vidman
vidman's Avatar
Re: Frame paint
I have used Bill Hirsch chassis paint for years with good luck. But there are many others that also work great..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 12-07-2013, 09:00 PM   #3
HotRod C/10
HotRod C/10's Avatar
Re: Frame paint
I used an industrial tractor paint that looks phenominal.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 12-07-2013, 09:42 PM   #4
davischevy
davischevy's Avatar
Re: Frame paint
Rustoleum code 7777. You can buy it in quarts, gallons and spray bombs almost anywhere and its easy to use and touch up.
davischevy is offline   Reply With Quote
Old 12-07-2013, 10:04 PM   #5
hugger6933
Re: Frame paint
Welcome to the site from the eastern part of frozen Arkansas. I am A born bowtie lover bleed bowtie Orange and own a bodyshop here in a small farming town of about 4500. I rebuild late model wrecks for a living for fun I do old muscle and trucks. there are tons and tons of great help on here. As soon as you can go to the home page click the home in the upper left corner then click on tech tips then your style of truck and enjoy. There is always something helpful there. I have and will again use the PPG's DPLF 90. It is an epoxy primer in black. I have used it on everything from a frame to a core support and not only does it last real well it looks great. Jim
hugger6933 is offline   Reply With Quote
Old 12-07-2013, 10:23 PM   #6
Jahloha
Jahloha's Avatar
Re: Frame paint
HotRod:
Whats the brand and information? I would be interested in researching this option a little bit.
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 12-08-2013, 07:50 AM   #7
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: Frame paint
Anyone use GM recondition black? I was thinking of trying it but seems hard to find. ??
Anyone know where to get some?
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 12-08-2013, 11:27 AM   #8
HotRod C/10
Re: Frame paint
Originally Posted by Jahloha View Post
HotRod:
I will get the info today....
LS SWAPPED
-1976 SILVERADO
Old 12-09-2013, 03:56 PM   #9
blastboy
Re: Frame paint
Thanks for all of the responses everyone. Has anybody ever had any experience with the Eastwood chassis paint? -JP
Old 12-09-2013, 04:28 PM   #10
dmartin1
dmartin1's Avatar
Re: Frame paint
i am giving valspar tractor and implement enamel a try. i havent startyed yet as im researching if brushing or spraying on is best and methods of stripping the frame etc.
i heard good things about the valspar so i figured i would get it to try.
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 12-09-2013, 05:49 PM   #11
davischevy
davischevy's Avatar
Re: Frame paint
Eastwood Chassis Paint is great, but you will get the same result with Rustoleum 7777.
As hugger6933 stated earlier in this post, PPG's DPLF 90 is the cats meow if you want the best, most durable finish. But read, expensive and harder to use, and use a good respirator.
I use the Rustoleum 7777 because I drive most of my cars and I can walk into any WalMart and buy touch up paint.
I have a trailer queen Corvette and Chevelle that have the DP 90.
Old 12-09-2013, 06:50 PM   #12
Sammy
Re: Frame paint
Used Eastwood chassis and Tractor paint both, didn't see any bigger advantage to either one. I think just compare the cost unless it is spending it's life on a trailer from now on.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 12-09-2013, 06:56 PM   #13
HotRod C/10
Re: Frame paint
Here is the info:
Valley Paint Manufacturing
Super Speed Satin Black V-2507
and I added Their Enamel Kicker to it. V-3001.
This stuff reduces with Zylene
LS SWAPPED
-1976 SILVERADO
