Old 01-09-2014, 01:42 PM   #1
61K10
61K10's Avatar
ft wheel cyl on 61 4x4
what are the correct ft wheel cyl's on my tk? 1 1/8" or 1" bore? my truck came with new cyl's and shoes/drums on it. all cyl are 1" bore, but i see two different ones. also bought new hoses from napa and they have the wrong ends on the cyl end. 7/16 inverted flair, the org ones just screw in (1/8?) with a copper washer. have seen somebody on here had adapters of some kind? anybody know anything about these adapters?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-09-2014, 02:20 PM   #2
bhc41051
bhc41051's Avatar
Re: ft wheel cyl on 61 4x4
There's an adapter you need. PM JPBrecheisen he can point you in the right direction.
bhc41051 is offline   Reply With Quote
Old 01-09-2014, 02:41 PM   #3
61K10
61K10's Avatar
i know the adapter that you are talking about, it's an odd ball as a 3/8nf bolt screws into the wheel cyl. so 3/8" male sae nf to 7/16" inverted flair.
1961 chevy K10
Old 01-09-2014, 03:02 PM   #4
60-66
60-66's Avatar
The gm part number for the wheel cylinder is 2412642 and 2412643 . Book calls it 1 1/8. Wagner number 34196 34197 .
Jon
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 01-09-2014, 03:03 PM   #5
NurseBen
NurseBen's Avatar
I had the same issue at NAPA but they did have the 1/8 screw in type, not sure on a part number but on the hose it reads; SAE J1401 1/8 HL SUNSONG. Hope this helps
NurseBen is offline   Reply With Quote
