Old 10-28-2012, 12:35 PM   #1
Shooters_7
LY6 Fuel System questions
I have a 2009 LY6 with a few thousand miles on it attached to a 4L80e transmission. I need some help with someone who's has already done this with running the fuel system. I have a Boyd fuel tank with a built in electric pump if that helps. I'm guessing I use the filter with the built in fuel regulator??? Pics of the current fuel line and what I think is the correct fuel filter. Any help with this would be great!
What size fuel line did everyone use?
What are the size fittings for the Boyd fuel tank?
Conner
1965 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=535078
Shooters_7 is offline   Reply With Quote
Old 10-28-2012, 01:03 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: LY6 Fuel System questions
Looks like you on track to me. I used 3/8" s.s. hose and 6AN connectors...replacing what you have there. So it's s.s. hose from tank to filter/reg...and s.s. hose from filter/reg to fitting on the oem steel fuel rail using Russell 6AN adapter. My return is also s.s. hose. Now is all that expensive s.s. hose required? No.....just purdee to look at.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-28-2012, 01:18 PM   #3
Shooters_7
Thanks, all about stainless.... Where did you get your hose from?
Conner
Old 10-28-2012, 02:11 PM   #4
68GMCCustom
Summit Racing....they had it on sale.
Kurt -
Old 10-29-2012, 05:10 PM   #5
Shooters_7
Whats the fitting size that connects into the fuel rail? I'm rounding up all the part numbers to order along with the fuel line. Pic attached!
The oil cooler lines are in my way as well for the Porter Built engine mount. Do you know fittings and sizes for that? Thanks
Conner
Old 10-29-2012, 07:43 PM   #6
clinebarger
The line size is 3/8", If your going to use AN line......You need a 3/8" Quick disconnect to -6 AN male fitting.
Block off the oil cooler....With one of these http://www.ebay.com/itm/LS1-LS2-LS6-...sories&vxp=mtr
Not saying to buy that one....Just an example. You will need a gasket & bolts too.
clinebarger is offline   Reply With Quote
Old 10-29-2012, 09:39 PM   #7
Shooters_7
I was hoping to keep the oil cooler and run braided stainless steel lines, otherwise I'll block it off as I won't be towing anything.
Conner
Old 10-29-2012, 10:19 PM   #8
68GMCCustom
then keep that oil line block/manifold, remove the tubing, tap for NPT to AN fittings and connect your s.s.hose.
Kurt -
Old 10-30-2012, 07:34 AM   #9
Shooters_7
I'll take it off Friday and see what issues I'll run into doing this. Hopefully its that easy.
Conner
Old 10-29-2012, 11:20 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'll warn against using the old design Russel quick disconnect fittings. There have been batches of them that have popped off causing engine fires etc. My pressure fitting popped off (return style system) at the rail and pumped gas right onto the headers. I caught it ASAP and avoided damage but its a sketchy ass problem and Russel REFUSES to aknowledge or recall the problem, despite many cases of total loss (see ls1tech thread on the topic) The re-released the design with a screw on retainer that makes it impossible to pop off.
Not trying to scare you, but it scared the hell out of me.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-30-2012, 07:31 AM   #11
Shooters_7
Someone else told me the same thing and said to use these instead. I'm not going to risk an engine fire. Thanks for the advice!
Conner
Old 10-30-2012, 02:11 AM   #12
mcmlxix
Collector of Projects
mcmlxix's Avatar
I bought a 3/8 compression to male -6AN fitting to use for the fuel lines.... I haven't run it yet... if the oil lines are 3/8" line you could do the same.
http://www.summitracing.com/parts/rus-639213/overview/
Rich
1972 K5 Blazer CST Click HERE
Old 01-13-2014, 09:09 PM   #13
Shooters_7
Another question. The line with the yellow arrow was used for what in the factory vehicle? It seems like it may have run to the fuel tank as well as some sort of vent line or something? What needs to be done with it now as I have a boyd tank? Thanks in advance!
Conner
Old 01-13-2014, 09:26 PM   #14
mcmlxix
mcmlxix's Avatar
that goes to the evap canister located near the factory tank... part of the emissions system... there is a purge solenoid too...
Rich
Old 01-13-2014, 09:39 PM   #15
Shooters_7
Whats the best thing to do with this line, do I really need a canister or is there another option?
Conner
Old 01-13-2014, 10:19 PM   #16
mcmlxix
mcmlxix's Avatar
Some states (or local county) require complete emission systems for vehicles that have a motor swap from a newer vehicle. If not required, you can block it off at the intake.
Rich
Old 01-14-2014, 08:55 PM   #17
Shooters_7
Its Texas....they don't care too much!
Conner
Old 01-14-2014, 10:43 PM   #18
littlevictories
i pulled my evap solenoid, ran a 1/2-20 tap in.
same pitch drain plug from the dorman bins and a nylon washer.
done deal
littlevictories is offline   Reply With Quote
Old 01-14-2014, 11:58 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Its normally closed, so with the codes deleted and the wire unhooked, it can just sit there. Mine's under an engine cover anyway.
Old 01-16-2014, 07:47 PM   #20
lynnfield
The Waco Kid
lynnfield's Avatar
Is the filter/ regulator required with the return less system? Maybe a dumb ??? here, but I am running the same set up with a Boyd Welding tank/ and the aeromotive 340 in tank pump. The donor truck had none of that, just a line off the in tank pump to the fuel rail and another line for the vapor canister. Also, I have read a few others having issues with fuel smell without the vapor canister.
lynnfield is offline   Reply With Quote
Old 01-16-2014, 09:37 PM   #21
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The donor truck most likely had a return style system, running a 5/16 line back to the tank. If you switched to a non-return style rail, then you must use the 'vette filter/reg unit (which has a fuel return built in.)
If you are running a performance tune and no cats...its probably gonna smell a little like fuel all the time haha. When I get out of my truck, I smell like the dragstrip after a day of driving. I have no vape cannister, and it doesn't smell any different than any of the pre-emissions cars I've owned, just a lot MORE exhaust.
Old 01-17-2014, 08:43 PM   #22
lynnfield
The Waco Kid
lynnfield's Avatar
Some good info in this thread:
http://67-72chevytrucks.com/vboard/s...ht=fuel+system
Old 01-17-2014, 08:57 PM   #23
mcmlxix
mcmlxix's Avatar
I used a fuel pump from a 2005 truck that has the regulator built in and is designed to work with the returnless system.
Rich
Old 01-18-2014, 04:12 AM   #24
LS-K
mcmlxix,
Any chance you can tell me what exact 2005 truck you used that pump off of? I've got an LS6 from a CTSV that's return-less. I'm about to set up my fuel system. Thank you so much. Also if you had an evap line and if you did, what you did with it. Where did you route/send it to? Thank you so much in advance.
LS-K is offline   Reply With Quote
Old 01-19-2014, 02:59 AM   #25
mcmlxix
mcmlxix's Avatar
Originally Posted by LS-K View Post
mcmlxix,
GM# 19167467 or FG0340
Check out my build thread in my signature.... I built a custom tank and used a weld in fuel pump ring from www.vaporworx.com They come in aluminum and stainless... The rings were originally designed to use the CTS-V pumps for the Pro-Touring crowd....
Rich
