Any squares with over 150k on original engine?
Back in the 70's I always figured most Chevy engines were almost worn out shortly after 100k miles. My 76 GMC has 60,000 miles on odometer which I assume is 160,000 but how can this engine still be running so good? The guy I bought it from was the 2nd owner who bought it from his uncle the original owner. He was a barber that used it to haul his camper.
The 2nd owner that I bought it from put a new cam and aluminum heads and intake and oil pump but he said he didn't touch the bearings. I guess the new heads would make it run pretty good and not use too much oil but I am having a hard time believing the original engine can go this far, especially hauling a camper from time to time in it's early life. I checked the deck surface and the vin matches the truck. It doesn't smoke or use much oil either. Has anybody else gotten a lot of miles out of their old square's original engine?
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Any squares with over 150k on original engine?
with proper care ( tune ups, oil changes with good oil and filter and fuel system services) I see no reason why you cannot get closer to 250-300K out of a motor.. the problem with a truck is a lot of them were used as work horses and not properly cared for and that caused premature motor failure. One of the best examples of that is the army vehicles that weren't properly maintained and at 40K or so need rebuilds
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
200,000 miles on my 4.3L V6.
Never had more than the air cleaner off it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
We had an old service truck that was used for years by a local welder it had over 400k on the ticker it was on its 2nd tranny but nothing more than maintenance on the motor normal starter alternator type things
the old k20 i had had 1 million on a factory replacement engine. never was rebuilt. the first engine was screwed up by a garage leaving oilfilter gasket on was replace by gm.
156 on my Suburban. I believe I could pass it off for 56. It runs perfect without any leaks. It does smoke occasionally on start up, but doesn't use any oil between changes.
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
My 82 with 250 6 cyl and 3 spd manual will soon reach 300K. I purchased from original owner. Was used mainly as a DD and no towing or heavy hauling. He said he thought he had replaced clutch once, but otherwise only tune-ups, brakes, oil and filters. Leaks some oil but no smoke and makes good power. Chip.
78 Big10 454
![]() Join Date: Jul 2008
180,000+ on my factory original 454.
1978 Chevy SWB C-10 2WD 454/400 |
151.000 on my '87. Valve seals are shot and compression is getting a little low, but it continues to chug along.
At the body shop.
Had an 86 with 317k when I wrecked it 91
" That didnt make it any newer " " Dont antique the equipment " |
Dad bought an '86 K20 new, and the 350 in it has had two valve jobs but no bottom end work and is currently at 361,000. My '85 454 shows no signs of having been apart and has 113,000 on it - I got it at 78K and I think it's highly unlikely it had internal work before then, judging by how straight the truck was. It uses some oil (about 2 quarts every 3,500 miles), but isn't showing any signs of being tired and I think a lot of the oil usage is the valve seals. BTW, the K20 has spent most of its life using conventional 10W40 - Valvoline most of the time.
I've seen or heard of too many carbureted Chevy V8's with plenty of miles on them to think it's the design or technology of their day that limits longevity; browsing ads for 80's and 90's (I know, fuel injected, but that only makes my point further) trucks on Craigslist and seeing so many with less than 175,000 miles but have already had the engine rebuilt or replaced seems to indicate a good number of people just don't know how, or don't care enough, to treat the engines properly. Good oil changed regularly, sensible use and maintenance, addressing a problem when it arises, and letting the engine warm up go a long way.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
I imagine that being overdrive and high geared helped a lot of trucks not take so much wear and tear
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Engines were wore out sooner, but there wasn't an oil change place on every corner. I've seen more squares parked due to a blown transmission (picture 150k and never serviced) and body rot.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
My cousin has a '81 K30 single wheel with 350 that has over 500,000 on the original engine.
1967 Chevrolet Impala Sport Sedan Royal Plum Metallic (1967) My Dad ordered it. 33,xxx miles, parked since 1977. |
#15 |
My buddy has a 74 c20 with 400k on it
"DON'T TOUCH THE TRIM!!"-Early Kyler |
#16 |
Like said if taken care of any engine can run a long time.Years ago my dad had racked up 378k on a caprice wagon he had.If the trans didn't give out he would have kept driving it.
#17 |
#18 |
We had over 250K on our 305 in our 87 GMC when we replaced it with a new 350. It was still running, but had a miss in it, an oil leak, and was beginning to use some oil. GTT
GoTennTitans 1987 GMC Sierra 1990 GMC Sierra (stolen) 2003 Chevy Silverado |
#19 |
My Dad with (what is now) my '83 racked up 250k on it's original 350.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
#20 |
I have 164k on my 86's 305/700r4 combo. Neither have been apart yet.
1986 Custom Deluxe 10 1978 Caprice 2 door - sold 1937 Chevrolet 2 door sedan - project |
#21 |
Cruzzzn' Vet
217K original miles on my 83 Silverado, 305/700R4 combo, bought new
#22 |
I have had my since 78 since 78 (2nd) owner.
Two transmissions, 2 fuel pumps and 1 water pump. 2 radiators, 2 A/C compressors The clock shows 288K and the speedo was broke for about 11 months back in 81 so it has close to 300K or more. 3K mile oil changes ,lube and filters, valve covers have never been off runs just like it did back in 78 but it smokes a bunch when it starts, so I am changing it out to a 5.3 and 4L60E and pass it on to my grandson after I "brake it in" I has got 10 MPG since 78 and it did until I took it out of service back in August for the change out The engine only needs valve SEALS, AND ANOTHER PROJECT !!
#23 |
1987 R10, 207K on 6.2 diesel
As a reference, my 1990 GMT400 with the 4.3 V-6 was running strong when I sold it at 215K, replaced plugs once, wires twice (willNEVER buy Accel wires again), and one alternator. My 1999 GMT800 3/4 ton has 193K on the 5.3, ticks at start up then hauls the mail, got plugs at 100K. My 1997 3.4 powered minivan went 202K wth only intake gaskets and 1 set of plugs. My 2004 minivan flipped 150K today with only plugs and wires and 1 belt, and my dad and I put 400K+ on a 250 inline in a 67 Biscayne (4 door stripper Impala) without having the head off or the pan down, took 3 clutches and 4 set of brakes and lost the diff at 150K. Change your oil! Keep the grit out of the bearings! Fuel injection puts a lot less crap down the cylinder walls cold. Modern ring technology is much easier on the bores. Personally I find that the bodies rust off before the motor wears out.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
#24 |
That tick is probably piston slap. Common on 5.3 due to short skirts...my 5.3 does the same 230k
#25 |
mine had plenty of rust wife papa had it since new.
