Old 06-30-2012, 09:15 PM   #1
DCREIF
Starting a 1971 c10 build
Recently purchased a 1971 c10 and starting to rebuild
DCREIF is offline   Reply With Quote
Old 06-30-2012, 09:42 PM   #2
DCREIF
Re: Starting a 1971 c10 build
how do you add pics... new to this forum
Old 06-30-2012, 10:10 PM   #3
Tinkermc
there are sections that explain everything, but welcome to the forum
Tinkermc is offline   Reply With Quote
Old 07-01-2012, 01:47 AM   #4
suspect
suspect's Avatar
with your thread open, click the tab that says "go advanced". it's to the right of the "quick reply" tab. then scroll down about half way, you'll see a tab "manage attachments". browse, download your photos.
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 07-04-2012, 05:12 PM   #5
DCREIF
Figured out how to add photos today. The truck is at it's new home and is in the process of being torn apart. Will post progress!!!
http://i1252.photobucket.com/albums/...dcreif/jpg.jpg
Old 07-04-2012, 05:14 PM   #6
DCREIF
off the trailer it goes!!!
http://i1252.photobucket.com/albums/...dcreif/006.jpg
Old 07-04-2012, 07:25 PM   #7
DCREIF
The parts pile has started!!!! No turning back now!!! Ha Ha
Old 07-04-2012, 07:33 PM   #8
Lee H
Lee H's Avatar
Great start, welcome to the board.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-04-2012, 07:34 PM   #9
Tinkermc
from the loks of the frame the parts pile must be large by now. Keep the pics commimg
Old 08-13-2012, 11:48 AM   #10
DCREIF
Re:1971 c10 build / extra parts listed
How do you post items for sale....
I have the following parts I would like to post for sale from my 71c10.
1.) 250 inline 6 with attached sm465 trans.
2.) upper and lower a-arms (control arms).
3.) C10 factory Trailing arm crossmember.
4.) Factory Disc Spindles with original disc, hub, and calipers.
5.) c10 250 motor mounts.
6.) 1985 c10 full crossmember Disc to disc and everything in between.
7.) factory in cab gas tank.
8.) bench seat.
9.) driveline.
10.) Rear brake drums inner and outer.
11.) heater box set up (inner and outer)
No reasonable offers refused, Make offer!
Old 08-13-2012, 11:58 AM   #11
DCREIF
Re: 1971 c10 build--- Here is the latest progress!!!!!!!
Someone needs to buy the parts listed, so I can clean out my driveway, make my wife happy, and most important fund additional parts.
1.)
2.) Upper and Lower A-arms (control arms). 100.00.
3.) C10 factory trailing arm crossmember. 75.00
4.) Factory Disc Spindles with original disc, hub, and calipers. 100.00
5.)
6.) 1985 c10 full crossmember Disc to Disc and everything in between. 300.00 obo
7.) Factory in cab gas tank. 50.00
8.) Bench seat. 100.00
9.)
10.) Rear brake drums inner and outer. 75.00 (axle not for sale)
11.) Heater box set up (inner and outer). 100.00
12.) 1971 Wire harness (Cab) 50.00.
Anyway here is the latest progress.
The rear discs are from an eldorado, axle major turned to fit hub hats, aids in using factory replacement parts, caliper also from an eldorado.
Waiting on the front disc rotors to complete chassis.
Tank is an EFI from Boyd.
5.3l with 224 tx speed cam(on order), will be converted to a DBW.
Power coated frame thanks to a local shop.
cpp suspension, 2.5 spindle front, 3" spring rear.
Parts needed and will trade for.....
1.) 4l60e or 4l65e 2wd trans.
2.) 67-68 grill
3.) 67-68 hood
4.) 67-72 passengers side door.
5.) 67-72 passengers side swb bedside.
6.) 67-72 tailgate with hardware, someone needed mine more than I did!!!!
Old 08-13-2012, 12:07 PM   #12
brianthelion02
Overdrive club
brianthelion02's Avatar
Nice work,can't wait to see more.
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 08-13-2012, 01:35 PM   #13
DesertCat
DesertCat's Avatar
Wow, you really jumped right in! Where in AZ are you?
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 08-13-2012, 01:44 PM   #14
67c10rustbuket
67c10rustbuket's Avatar
Hey now slow down over there! Nice (FAST) work!! I like it a lot.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 08-13-2012, 02:20 PM   #15
True 67
Nice start....keep the pics coming!!!!!
True
True 67 is offline   Reply With Quote
Old 04-05-2014, 04:11 PM   #16
DCREIF
Started welding the cab...
