Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-24-2013, 02:20 PM   #1
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Show your roll cages!
Hey there! Looking for different ideas on cage design for our trucks. Especially interested in how the rear bars go through the window/cab of the truck and tie into the frame. Also how the front bars come through the firewall and tie into the front portion of the frame.
Show off your cage and design. More pics the merrier!
thanks
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 11-25-2013, 01:01 PM   #2
slowtruck
Re: Show your roll cages!
I've searched and think I've seen every pic on here, but would love to see more! I just got my bender and bend tech program to start my cage.
slowtruck is offline   Reply With Quote
Old 11-26-2013, 12:35 AM   #3
Captainfab
60-66 Nut
Which Bend Tech software did you get? If you got BT Pro, you can build your entire cage before you ever cut a piece of tube. It can take a little bit to learn the software, but it is very cool for designing tube fabrications. One of the keys to accurate tube bending with Bend Tech is calibrating your dies correctly.
Old 11-26-2013, 04:36 AM   #4
slowtruck
I just got the Bend Tech EZ, because I don't plan to go crazy on my truck and just putting in a 12pt.
What do you mean by ''calibrating your dies''? The bender I've got said they are on a 5'' center line.
Any insight and help will be very appreciated!
Old 11-27-2013, 12:25 AM   #5
Captainfab
60-66 Nut
You will have to perform the steps necessary to calibrate your die, in your bender. When you do this, that will give you the info the software needs in order to give you the info to make exact bends in your tube. You need to do this because every bender and die set can vary. These steps hould be outlined in the owners manual for the software. If not, contact Bend Tech and they will be happy to help you with that info. You will have to have the serial number and some other info for your copy of the software handy to give them.
What brand of bender do you have?
Old 11-27-2013, 05:38 AM   #6
slowtruck
I see, but I haven't installed the program yet and will read more on the prgram before I do. I picked up the Woodward bender and have made a few bends with it and it works well.
Old 11-28-2013, 12:49 AM   #7
Captainfab
60-66 Nut
I think the Woodward Fab bender is the bender that Mittler Bros used to make.....maybe they still make it, but just for Woodward Fab.
Old 11-28-2013, 02:51 PM   #8
slowtruck
SweetandLong68- Are you thinking of doing your own cage also and if so what's you plans for your truck?
Also sorry for turning your thread it to about me and I will post pics of my cage for you when I get more of it done.
Old 11-28-2013, 03:20 PM   #9
SweetandLong68
Your UncleBen
Its is a possibility.... Even if we don't do the cage ourselves I still wanna know what I want and need to be looking for. Looking to stay 8.50s and slower.
Chris
Old 12-03-2013, 02:52 PM   #10
bcdeutsch731
bcdeutsch731's Avatar
I found a couple pic's of my cage when it just got done. This cage got a NHRA sticker for 8.5 and slower last year.
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning.
8.3@168mph 1700+ HP
bcdeutsch731 is offline   Reply With Quote
Old 12-04-2013, 12:15 AM   #11
Captainfab
60-66 Nut
I'm surprised you got away without any cross bracing between those rear bars.
Old 12-04-2013, 02:37 AM   #12
softballnrd27
Always a work in progress
softballnrd27's Avatar
What are ya'll using for back glass with the bars going through it?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 12-17-2013, 12:18 AM   #13
RICKSRAT
RICKSRAT's Avatar
Pics of mine with a S&W main hoop with custom bending on rest of cage.
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30
Old Motor: 60'. 1.43
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
RICKSRAT is offline   Reply With Quote
Old 12-17-2013, 12:19 AM   #14
RICKSRAT
RICKSRAT's Avatar
Main hoop
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 12-17-2013, 12:25 AM   #15
RICKSRAT
RICKSRAT's Avatar
More
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 02-04-2014, 03:33 PM   #16
gofastnut
gofastnut's Avatar
BUMP! I wanna see more!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 02-04-2014, 06:35 PM   #17
slowtruck
I just started on mine so no pics yet, only have the outriggers to tie the frame to the cage installed. I have been fixing the floor pans so that everything is rite before I started the cage work.
Old 02-05-2014, 04:56 AM   #18
INSIDIOUS '86
INSIDIOUS '86's Avatar
Anyone get a cage done without using plastic rear windows cut for clearance?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-05-2014, 02:19 PM   #19
vin63
It's Better With Nitro
vin63's Avatar
if the rearward bars are 1 5/8 dia, and mounted to the horizontal section of the main hoop, additional bars are not necessary. If the rearward bars are smaller than 1 5/8 dia, then additional bars are required according to the diameter used.
You'd have to build it to the roadster spec to eliminate the rearward bars from a main hoop configured roll cage. Otherwise, if you use a traditional roll cage with main hoop, you'll have to run rearward bars and then will end up passing through the rear window or cab itself.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-10-2014, 03:54 PM   #20
familyfast64
familyfast64's Avatar
There's a few u tube videos of trucks with cages I've been looking at. Like this one dudes fifties Chevy, he went out through the metal above the window but I don't know about in your truck.
Live and let live
familyfast64 is offline   Reply With Quote
