need help on flip kit on 2wd blazer
ok so i bought lowering springs for the front 3' and i did the flip kit in the back but the back sits really low i mean low what would be better to do? take the flip kit off and just put drop shackles?
Cruzzzn' Vet
Re: need help on flip kit on 2wd blazer
A flip kit on the rear is usually a 5/6 drop, for the front you'll need drop spindles to bring it down along with the springs
If you only want 4", you need to take out the flip and use a shackle and hanger. Of if you want to keep the 6" rear drop you have now, you would need to use a drop spindle for 2" and a 2" or 3" spring. You would have to experiment a little. With the 6" rear drop, you will probably have to do a C notch in the frame, or the axle will hit on big bumps
98 GMC Sierra Ex Cab, cowl hood, Euro LED lights, 30 bar billet, Whipple Supercharged 350 Vortec: Forged flattops, E-Tec aluminum heads, Comp Cam, Scat crank and rods, Granatelli Mass air flow, Headers, Flowmaster exhaust , Complete MSD Ignition, Custom Tuning, intake spacer , ported throttle body, AC Delco port injection upgrade, Roller Rockers, Power Pulleys. Gear Vendors Overdrive. Soon to hit a dyno. 2/4 drop(for now). 95 Chevy S-10 Ex Cab 4.3 5 Speed 2/3 drop, Euro lights, billet grill, More to come. The Daily Driver |
Thanks for y'all help
You'll definitely need spindles to get anywhere close to level. Mine is 3" spindles, Moog 6102's and a flip. My flip sat too low also. I flipped my rear hanger so the shackle points down. It took about 1 1/2 inches out of my drop. Has about 1"-1 1/2" of rake front to rear.
Can u send me pic of how u did that back? Of the flip shackles 832-691-2338 or email them
To me gmc1213844@yahoo.com |
i lowered mine 5" in the front and to match it in the rear i put in 2" shackles,removed the 1" spacer under the leafs and removed the overloads-it turned out good.
