Park/Neutral/Reverse/Drive signal to ECM
The LS swap book I am reading mentions that the ECM needs to know when the vehicle is in gear or not in order to determine idle speeds, etc. However, reading the Chevrolet Performance E Rod harness instructions, it makes no mention of this signal going to the ECM. I plan on using a crate LS3 with the Chevrolet performance engine controller and harness. Any idea how the GM harness is getting this data? See here: http://paceperformance.com/files/pdf/19244807E-ROD.pdf
meowMEOWmeowMEOW
Re: Park/Neutral/Reverse/Drive signal to ECM
The signal is off of the Neutral safety switch, which is on the transmission portion of the harness. It can be run without (I don't use it), or can be hooked up to an aftermarket shifter or switch. Its just a contact switch.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
So where is the neutral safety switch on the 4l60e? I guess I've read so much on this subject even I'm confused. You have the neutral/park safety switch on the factory steering column. Then if you have a truck transmission, you have a gear position switch on the drivers side of the tranny. But if you have a car 4l60e there is no switch? I am going to be running the GM Supermatic transmission controller and harness with a 4l60 or 4l70e. So you are saying the transmission controller takes this input from its harness, and then relays it to the ECU?
#4 | |
meowMEOWmeowMEOW
You don't NEED any of them, but you only want to run 1. Because its just a contact switch, it can be mounted anywhere that connects when in park. You could put it on a toggle switch if you REALLY wanted to, but it would just be weird and probably a recipe for headaches. on the range selector ![]() Aftermarket NSS for custom shifters ![]() And I couldnt' find the column shift one, but they all wire up the same. You can use anything you want to make the connection.
![]() Join Date: Sep 2005
Mines not hooked up its not really needed
