Old 02-23-2014, 03:03 PM   #1
Sloan66
71 Brake light?
I have a 71, the brake light works when the park lights are turned off, when I turn the park lights on and step on brake the left brake light does not work, but the right one does. Like I said both work fine as long as I do not turn park/headlights on.
Thoughts?
Sloan66 is offline   Reply With Quote
Old 02-23-2014, 03:14 PM   #2
Willys47
Willys47's Avatar
Re: 71 Brake light?
my guess is a poor ground on that light that is not working
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 02-23-2014, 03:40 PM   #3
Jake1971
Jake1971's Avatar
Re: 71 Brake light?
This reminds me of a problem I had several years ago on my '68 c10. After carefully inspection of all associated parts I replaced the turn signal switch in the column since it had a hairline crack in the base. Once that was completed everything worked as intended.
1971 Bone Stock C10 project "Jake"
1997 Sierra SLT factory short bed "Silver Bullet"
Jake1971 is offline   Reply With Quote
Old 02-23-2014, 07:00 PM   #4
Sloan66
Re: 71 Brake light?
Had a new headlight switch replaced that, and ran a ground wire from bed to frame, lights are brighter, but still the left brake light is inop when the headlights are on, so...guess I try the turn signal switch next.
Old 02-24-2014, 01:24 AM   #5
swamp rat
swamp rat's Avatar
Re: 71 Brake light?
What willys47 is saying it there could be bad grounds at the light them selves. To add to that the trucks bed needs to have ground straps to the frame as does the cab itself.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
