cpp booster kit disc/disc
part number 6772BB4 http://www.classicperform.com/Store/...ck/6772BBD.htm
so im converting to 4 wheel disc brakes and need a new mc. i was looking into this one linked above. im replacing the brake lines for the right size. its a 68 longhorn. anyone have experience with this product? any issues i might have?
![]() USMC SEMPER FI 68 Chevy Longhorn 350/400 factory posi |
Re: cpp booster kit disc/disc
I'm using that booster. Working just fine so far. CPP is the most popular MC/booster setup, I'm sure you'll be pleased with it.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
Junior Member
I have 15k on their disc/drum set up and it works great.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
![]() Join Date: May 2013
Make sure to check the fitment of the master cylinder to booster, if it is too tight your brakes will lock after a short time driving , I have had this problem with 3 different cpp kits , 2 washers in between the master and booster are what is needed to correct it , cpp does not mention this in their instructions . Going from stock brakes to this system is a huge improvement . Im sure 60 to stop distance is cut close to in half
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
Yes I do. In fact I'm patiently waiting on my replacement from CPP. The booster leaked where the master bolts to it. The master cylinder has two plugs on the opposite side. the rear plug leaked brake fluid while I was bench bleeding it.
I had read there could be problems with the booster leaking but had not seen any posts on the master cylinder. Both of mine failed. Stay tuned and I'll let you know if the replacement booster works. I've already purchased another mastercylinder so I won't be using the replacement when it arrives. ![]()
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
awesome! i just ordered one. cant wait to put it on.
z10- ill keep that shim in mind when i get around to testing it out. oh and ill be sure to take some pictures of the project! ![]()
