My 66 step-side
My dad gave me his old 62 fleet side back in the late 80s for my 1st truck. I have wanted another one ever since. Always loved the step-sides and finally found this one with a donor 283 and turbo 350 trans with the power glide in the bed. All was there but not hooked up.
A couple of weekend and a few hundred bucks later and she runs and almost drives. It seems the "57" 283 runs great but the TH350 is shot. But no all is lost. My buddy who is building a 72 K5 Blazer with an 06 Duramax drive train has a turbo 400 I can HAVE!!!! And I get to use his lift, welder and tools to do the swap. I still can't driver her and already on tranny #3. Upgrade every time too. Not bad. I will run it like it is for a while and build as I get $$$ for it. I plan on swapping the cab as the PO beat the snot out of the firewall for the BB he had in it, the floor is rusted out and a sunroof installed. Last edited by jesseo; 05-02-2013 at 06:44 PM. Reason: Adding photo |
Re: My 66 step-side
Here's a couple of photos for starters. I will post the Turbo 400 swap next weekend. Hope all goes well. Any ideas or links of previous swaps are welcomed, desired and appreciated.
There is some amazing talent on this site. I am glad I found it. ![]() ![]() |
Re: My 66 step-side
Looks like you have a good project. From the pics it looks good except the floor. Is that the only metal work you have?
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
But Found Her 25yrs Later!
Re: My 66 step-side
Welcome.
Who Me?
Re: My 66 step-side
Nice truck!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Re: My 66 step-side
Re: My 66 step-side
Re: My 66 step-side
I wish it was. The firewall was beat with a hammer and a sunroof installed. There is a great wrecking yard about an hour and a half away that has all kinds of old cars and trucks. I think I will see what a donor cab might run me.
Senior Enthusiast
Re: My 66 step-side
Welcome to the forum. Too bad about the previous owner "improvements", but at least you have a nice looking starting point.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Re: My 66 step-side
Update. Got the TH400 in not because it is the best set up with the 283 but the price was right. FREE. Had to move the engine and trans back 3 inches to where it goes and get a new cross member for the tranny. Now the headers fit great. Still need to secure the headers, finish exhaust, h/u trans cooler and weld the floor and stop the rust from getting worse. I promised my wife we could drive it this weekend. I will post pictures soon. The PO had a welder and lover to use it. Wish he knew how. Not that I do.
#11 | |
![]() Quote:
Re: My 66 step-side
Re: My 66 step-side
lol! Awesome truck, btw! Those floor pans should be simple to replace. The outside looks great. I feel your pain about the previous owner. Check out the "I hate the previous owner" thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=514042 Lots of laughs, and you might have something in common with them and could probably submit some funny examples...
#14 | |
Re: My 66 step-side
#15 |
![]() Join Date: Oct 2011
Re: My 66 step-side
Hey man how are those derby caps mounted on the rallies? Nice truck BTW!
1960 Chevy Stepside 2wd 1966 Chevy Fleetside 2wd 1965 Chevy Suburban 2wd 1965 Chevy Fleetside 4X4 1960 Chevy Fleetside BBW 2wd |
#16 |
Re: My 66 step-side
How else would the caps be on there..........welded of course
1965 Chevy short-step side, work in progress.... ............................____ ..................______l/___\____ .................|_/(0)\_ll____/(0)_l. |
#17 |
#18 |
Re: My 66 step-side
There's no way they would weld them on! You need access to the lug nuts. ...Or are you being sarcastic?
#19 |
Re: My 66 step-side
Not sure how they are attached. I've been too busy fixing what the PO did to this poor truck. Engine mount cut and engine moved WAY to far forward on homemade mounts. Tranny also on home made bracket, welded bolts and washers all over the frame. Washers were used as exhaust hangers. The trans cooler mounted under the passenger side floor, hmmmm air flow???? Had to replace tranny too. Bell housing fell apart as I took the TH350 out. Trans tunnel completely cut out and sheet metal welded in it's place. Beat the heck out of the firewall, I think, to fit the BBC that used to be in the truck, probably mounted to far back against the firewall. Removed the heater and WELDED a fan to the firewall. I do love the rally wheels and new tires though and the 283 from a 57 chevy seems to be strong. I love the body style and other than the normal floor rust the body is pretty straight. Other than the firewall and sunroof. I'll be taking pictures this weekend. I plan to get it where I can drive and work on it as I go. Some year it will be a GREAT truck.
#20 |
Re: My 66 step-side
Ha ha ok I take it back, maybe they are welded on. Sounds like a freakin headache man. Cant wait to see the updates. And pics of the wheels of you don't mind.
#21 | |
Re: My 66 step-side
#22 | |
Re: My 66 step-side
#23 | |
Re: My 66 step-side
Updates. Removed the cross member ![]() Next. Finish the exhaust. Cover the floor and rust (until I get a new cab) connect the new instrument panel and gauges. Clean up wires, vacuum lines etc. DRIVE THE WHEELS OFF HER. |
#24 |
Re: My 66 step-side
Good work man, its gonna stay real nice. Are those rivets on the wheel caps? Kinda hard to tell on the pic.
#25 | |
Re: My 66 step-side
