Speedo and Odo quit working
I need some help here. My speedometer and my odometer quit working. It was working good but when I got it back from the paint shop it's not working anymore. I climbed under the truck and checked to see if it was still hooked to the transmission and also check to make sure it was still hooked up to the dash. Everything was hooked up but it doesn't work. Any thoughts????
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Re: Speedo and Odo quit working
Unhook it at the trans, pull the cable out of the sleeve and see if it is broke in half. That's a starting point.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
Do I need to unhook it from the back of the cluster first?
KEEP ON TRUCKIN'
No, you should be able to unhook from the trans, grab the end of the cable and pull it out. If it's not broke, slide it back in, you may need to spin it a little bit to get it to slide back in the cluster.
78K & 79C Jimmys
I would,just to make sure it's in far enough,and before putting back in.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
I thought you had it pull the cable out from the other end (at cluster). I didn't think you could pull it the other way.
You could unscrew the tranny connection and put the cable end on a drill. Slowly turn it and see if the speedo moves (need 2 people). Make sure the cable connection is fully seated onto the cluster. Sometimes it doesn't get all the way pushed in.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
Do I need to have my dash out for this or can I remove the bezel and cluster with the dash installed?
![]() Join Date: May 2013
If the cable is broke you can have mine if you don't mind waiting for me to get back home in a few weeks
That'll work Tim. I don't need the speedo to work to drive it around town.
Unfortunately, yes you'll have to remove the dash, instrment bezel and then cluster to get to the cable. I'd first try just disconnecting from tranny and spinning it. That's a 3 minute job. Going into the dash....probably an hour job (I've done it several times!!)
I'll unhook it and spin the cable. Luckily I already have the bezel and dash out of the truck but was planning on putting it in this evening. Looks like I better leave it out.
Well I found my problem. Easy fix!
Got the cable replaced today. Cost me $ 6.99 and took about 3 minutes to replace it. Thanks for your help guys.
