Old 03-21-2014, 08:59 AM   #1
feedthafire
feedthafire's Avatar
4l80e installed pics, help!!!
So I have a 69 c10, I really want to run the Scotts under cab break kit (already purchased) but I am hesitating about revamping my break system. The bracket they have sold me is pretty badass, its gorgeous. The only reason I am hesitating, is because I am planning to go lq9/4l80e. I need a under shot of the 4l80e sitting to see if there is even enough room to run Scotts set up. I need to know how much room is between the trans and the frame rail so if any one could measure i would love it. Also i will have to route my exhaust somehow so its a pretty big deal for that as well.... PLEASE HELP A FUTURE 6.0 C10
Unless some one has already done this and can supply pics that would be a dream come true haha
Jordan
1966 Long Bed step side 4 on the floor
1969 Shortbed
1995 Mazda Rx7
Sanderson Roofing and Gutters
feedthafire is offline   Reply With Quote
Old 03-21-2014, 09:23 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: 4l80e installed pics, help!!!
I'm not 100% positive, but I don't think you will have room. I've included a couple different chassis pictures, and as you can see it would be tight to do that, but I guess anything is possible with enough fab work.
Hart_Rod is offline   Reply With Quote
Old 03-21-2014, 09:30 AM   #3
feedthafire
Wow, trans is beefier than I knew. I mean I read how much more they were than the 60s but I had not seen a under shot like this... well maybe ill throw the bracket in my closet and wait to swap and see how it sits. Ill leave it on the fire wall for now and install the rest of the Scotts parts I have...
1969 Shortbed
1995 Mazda Rx7
Old 03-21-2014, 11:29 AM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
Hopefully along with HartRod's pics, these will help you out.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-21-2014, 11:50 AM   #5
feedthafire
Ok, it does not seem unrealistic at all. Maybe i could notch the frame out a bit just to create a path for the exhaust to run...
1969 Shortbed
1995 Mazda Rx7
Old 03-21-2014, 12:18 PM   #6
feedthafire
I talked to Justin and he says it won't be a problem, but will be a tight fit. Thats perfectly fine for me.
1969 Shortbed
1995 Mazda Rx7
Old 03-24-2014, 10:55 AM   #7
Wasted Income
Boosted Member
I prefer it that way!
Turbo diesel
Old 03-24-2014, 10:59 AM   #8
Hart_Rod
Hart_Rod's Avatar
Old 03-24-2014, 04:29 PM   #9
Andy4639
Old member
Andy4639's Avatar
Wink Re: 4l80e installed pics, help!!!
Here are some of mine. 4L80E with pipes ran 2.5" It's pretty tight on the drivers side for sure. I'm running the B&M shifter cable on mine.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-24-2014, 07:12 PM   #10
tinydb84
tinydb84's Avatar
I know its not the question the OP asked (and not trying to highjack) does anyone have a pic of the height of the oil pan vs the tranny pan? Which one hangs lower?
David
Instagram: myfabguy
Old 03-24-2014, 08:03 PM   #11
Hart_Rod
Hart_Rod's Avatar
Depends on which oil pan you are running. The truck pan hungs lower. The Fbody pan is about level.
Old 03-24-2014, 08:13 PM   #12
Andy4639
Old member
Andy4639's Avatar
Question Re: 4l80e installed pics, help!!!
The pictures are of a truck oil pan.
Old 03-25-2014, 08:06 AM   #13
Wasted Income
Boosted Member
Here's mine with a deep B&M pan on the 80e, and an F-body pan.
Truck pans are bad, mmmmmkay? Busted mine open twice on my bagged C-10, lol.
Turbo diesel
Old 03-25-2014, 11:04 AM   #14
tinydb84
tinydb84's Avatar
Thanks for the info!
David
Instagram: myfabguy
