Old 01-28-2003, 01:15 AM   #1
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Lifting off my cab...
I'm just wondering how much work is involved in pulling the cab off of our trucks. I'm planning on bringing my truck into the city soon & pulling the cab off. It's an (almost) zero option '67/straight 6/3 on the tree. I think four buddies can lift off the cab (right?), but how much un-hooking is there? Brakes? Wiring harness? Cab mounts? Steering linkage? Shifter linkage? Parking brake? Fenders? Gastank/fuel lines? Am I forgetting anything? Many thanks in advance for any advice you can give...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 01-28-2003, 01:19 AM   #2
72MARIO
72MARIO's Avatar
Front Clip has 6 bolts you might want to take the doors off might save your backs. Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-28-2003, 01:59 AM   #3
67cst
i love summertime
67cst's Avatar
i cant remember exactly what me and my dad did, but with a cab fully gutted except for rear window and front winshield was removed with my dad and i, it was heavy but doable
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 01-28-2003, 03:07 AM   #4
jostrans68
Jostrans68
jostrans68's Avatar
Engine hoist with a 4x4 on top of it. I flipped the boom so the slot for chain was on top and i put two lag bolts in 4x to drop thru the slot. The with doors off run the 4x in the cab put it all the way forward in door opening from side to side and center the pivot point (lag Bolts) in the center of the Cab. then jack it up and it rolls easy I put mine on by myself...
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 01-28-2003, 03:20 AM   #5
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Loader tractor and 2 4" nylon straps.......no problem. Take the hood, cowl vent and front clip off first, makes everything else easier to get at. Unbolt the master cylinder, you can leave the lines hooked up if you're careful. I'd pull the distributor cap too jut to prevent accidental expense, heater hoses, fuel lines, unplug the wiring harness from the firewall. UNHOOK THE OIL PRESSURE LINE. hoses for the wiper washers, steering column, just disconnect the center link from the main part of the column, and pull the clips for the shift linkage and disconnect the shift rods. Unhook the clutch linkage, take the cable off the park brake pedal and pull it through the firewall. Pretty easy to take the cab off.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 01-28-2003, 10:27 AM   #6
Tynee
I miss this truck.
Tynee's Avatar
Are you gutting the cab anyway? If you are, I found out last weekend that 2 men can lift a gutted cab easily. I bet it didn't weigh 250 lbs.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 01-28-2003, 11:55 AM   #7
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
ol' buck,DITTO man, wegot the 4" straps too, cab was clear full excep gas was out, hdtwo brake drums, two ront disks, hood springs and other junk in it too, no proble lifting :-D
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 01-28-2003, 03:52 PM   #8
passthebuck
Thanks for the tips... I dont have access to a front end loader & my engine hoist is a fairly low-lift unit... I am going to pull the seat, dorrs & tank out before hand - 4 guys & some 2by4's SOUNDS about right.
I'm gonna put in new rockers, new floor boards & cab corners - I plan on laying the cab on its side on a block of styrofoam - good idea? Does anybody see any "hitches" in that plan?
passthebuck
#5642
Old 01-28-2003, 04:09 PM   #9
>X<
registered IWATA user
>X<'s Avatar
isnt there a ground strap to disconnect??????
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 01-28-2003, 04:10 PM   #10
7T1BURB
Here's a thought BEFORE you take the doors off...IF the doors close relatively "good" before disassembly you might consider drilling "pilot holes" through each of the hinges (where the hinges attach to the cowl and where hinges attach to door)....this simplifies a real troublesome task of realigning doors during reassembly...they may not be "perfect" when going back on, but at least you'll be closer and readjusting is made a little bit simpler. Realigning doors is generally a painful task!! Some folks don't want to drill holes in their hinges, but its a thought that you might consider....and make sure the doors are on (or a jig installed) and aligned before installing the rocker panels so everything lines up....guess how I know?? Been there, done that and got the T-Shirt!! Good Luck.
7T1BURB is offline   Reply With Quote
Old 01-28-2003, 05:43 PM   #11
cableguy0
actually tynee a gutted cab is about 560 pounds i took mine to the dump and left 560 pounds lighter the onyl thing left in the cab was the windshield
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-28-2003, 05:51 PM   #12
Figment412
There was a ground strap on mine...we did not find that till after the cab was already off. It took 3 people 4 hours at most to completely stip my truck. Just the cab itself was not to bad. One of the cab mounts were rusted though an had to bust out the torch to cut them off.
Save your money and do it right the first time.
1968 GMC short bed
1972 Cab
74 SB Chevy running gear
Figment412 is offline   Reply With Quote
Old 01-28-2003, 06:11 PM   #13
Tynee
I miss this truck.
Tynee's Avatar
560? Wow, I never would've thought that. I must be stronger than I thought, or all the wieght was on the other guy. hmmm.
Old 01-28-2003, 07:38 PM   #14
johnw67
hey guys weight cab is porportionate to amout of rust on it.
johnw67 is offline   Reply With Quote
Old 01-28-2003, 08:24 PM   #15
72c10
72c10's Avatar
when I pulled mine I gutted it but left the doors and glass in place and four of us lifted it and put it an a dolly that I made out of 2x4's that suported it where the cab mounts are. works great, has wheels so I can move it around and I dont have to wory about the cab twisting as much.
72c10 is offline   Reply With Quote
Old 01-28-2003, 09:43 PM   #16
passthebuck
thanks for that sweet tip 7T1BURB. It's good to know that i've gotta start saving up for doors now rather that later... (my current ones aint too good). Would the cab twist too much lying on its side (with one door on the top side) that WHEN I put it back on the frame, would the spacing around the doors be wackey? 560lbs? hmmmm not too bad...
passthebuck
#5642
Old 01-28-2003, 09:45 PM   #17
passthebuck
oups... thanks to ALL who have posted... much appreciated...
passthebuck
#5642
Old 01-29-2003, 10:58 AM   #18
7T1BURB
PTB:.....I would be careful of lying the cab on its side to complete underbody work because the chances of "cab twist" are increased. Mounting on a cradle at the body support mounts reduces chance of this twist while allowing both doors (or alignment jigs) to provide needed support. A cradle is not difficult to build and with wheels it allows you to roll the body around the shop....just another thought to consider before getting into metal replacement. Hope this helps.
Old 01-29-2003, 10:59 AM   #19
passthebuck
ttt
passthebuck
#5642
Old 01-30-2003, 01:25 AM   #20
passthebuck
ttt
passthebuck
#5642
Old 02-05-2014, 07:03 PM   #21
Dean'smeanmachine
Dean'smeanmachine's Avatar
Re: Lifting off my cab...
i built a cab dolly out of a couple pallets and some heavy-duty wheels
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 02-05-2014, 07:12 PM   #22
passthebuck
Thanks Dean.
You resurrected an oldie here!
I ended up rebuilding the cab floor on the truck on the frame. It was a ton of extra work & it's not nearly as nice as I would like, but it's solid & road legal.
passthebuck
#5642
Old 02-06-2014, 11:23 AM   #23
Dean'smeanmachine
Originally Posted by passthebuck View Post
Thanks Dean.
LOL ten years later. this thread has helped me decide wheather to take it off or not. i went with taking it off.
sounds like your truck came out nice.
my truck is going to be a driver too. i just want to start fresh.
Dean
in God we Trust
Old 02-06-2014, 12:23 PM   #24
54blackhornet
54blackhornet's Avatar
I just pulled all the sheet metal off my K-10, used a over head crane, pulled the clip first. Then the box, last was the cab. Go slow and be safe. I also used a big 4x4 thru the doors (top of window frame) to distribute the weight of the cab as we lifted the cab.
71 C-20
07 Magnum RT AWD
54blackhornet is online now   Reply With Quote
Old 02-06-2014, 12:47 PM   #25
67 cst swb
67 cst swb's Avatar
taking the cable off the park brake lever and pulling it through the firewall was the biggest issue for me on both my 67 & my 68
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
