Old 04-06-2014, 10:13 PM   #1
pudula
1960 C10 Won't Start! Help Please :(
Truck - 350ci motor, HEI, 700r4, 1960 Chassis
Story - started right up and pulled it out of the garage, washed it up. Go to start the truck to go cruise and she's dead as a door nail. First click of the key turns on stereo just fine, lights are all good, etc. Turn to start it and it wont even crank or anything.
Tests - starter tested ok, battery tested ok and has 12.5 volts. Bought and installed new ignition switch, nothing changed. Tried jumping it, nothing. All connections checked, battery terminals cleaned, etc.
Any ideas? I'm stumped.
pudula is offline   Reply With Quote
Old 04-06-2014, 10:51 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: 1960 C10 Won't Start! Help Please :(
Check your fuse block and rewire the ignition switch...with new wire, also make sure your ignition wire is hooked up on the right terminals. There's a ground issue or electrical failure somewhere.
Old 04-07-2014, 11:23 AM   #3
jmack91z28
jmack91z28's Avatar
Do you have 12v to the starter? Check your grounds as well.
1961 C60 Viking 8' Dump 261 SM420 2-Speed Rear
1966 C10 Fleetside 350 W/ Saginaw 4 speed
1985 K10 Chevy 6.2 diesel 700r4 longbed
2001 Dodge 3500 Dually 24v NV5600 4x4
USMC Reserves
Jason
jmack91z28 is offline   Reply With Quote
Old 04-07-2014, 05:08 PM   #4
williamdale
You could have a fuseable link blowed.Gm used a wire that would burn into it acts a s a fuse
If the lights come on check at the starter if I remeber wright it goes on the solenoid right behind the batt cable.
williamdale is offline   Reply With Quote
Old 04-07-2014, 05:38 PM   #5
morethanstock66
morethanstock66's Avatar
Starter solenoid?
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
