Old 03-30-2014, 02:42 PM   #1
Jfarns03
Jfarns03's Avatar
Moser Diff cover
Do you think this will clear the trac bar?
http://www.moserengineering.com/othe...-gm-truck.html
A place for everything, everything in its place.
Check out my build thread!
http://67-72chevytrucks.com/vboard/s...43#post6129043
Jfarns03 is offline   Reply With Quote
Old 03-30-2014, 05:44 PM   #2
Z10
Z10's Avatar
Re: Moser Diff cover
CPP makes a trac bar with a bend that should work.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 03-31-2014, 09:10 AM   #3
suspect
suspect's Avatar
I'm using that diff cover and the cpp bent bar. I have a small C notch & bags in the stock spring location. I had to grind about a 1/2" off the corner of the cover to clear the bar. I'll post up a pic later today. There's enough meat in the casting to not affect it any.
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 03-31-2014, 09:52 AM   #4
msgdsrf
You can also try http://www.lpwracing.com/Ultra_GM/Ultra_GM.html
Same idea but low profile
msgdsrf is offline   Reply With Quote
Old 03-31-2014, 02:53 PM   #5
Jfarns03
Jfarns03's Avatar
I really appreciate the suggestions ! A photo would be great
Old 03-31-2014, 10:26 PM   #6
suspect
suspect's Avatar
I ground it back to clear by about a 1/4". You can see the knick in the powder coat where I didn't realized it was hitting at first.
Daniel
Old 03-31-2014, 10:54 PM   #7
GMC Canuck
I have that diff cover with nolimit's trac bar. It clears, just. 4" drop on the rear.
I may follow suspects lead and adjust the cover for insurance.
GMC Canuck is offline   Reply With Quote
Old 03-31-2014, 11:37 PM   #8
suspect
suspect's Avatar
In that pic, its aired up higher than I will probably ever have it at. I just didnt ever want to guess if I was going to hit.
With springs, being set at a limited height travel, it should be fine.
Daniel
Old 04-01-2014, 02:51 AM   #9
Jfarns03
Jfarns03's Avatar
I haven't taken that into account. I have a static 6in drop in the rear. I'll be shaving quite a bit off the diff cover then?
Old 04-01-2014, 08:19 AM   #10
suspect
suspect's Avatar
With a 6" drop, the bar will probably always be under the cover. You may have to grind a little of the corner off, but not as much as i did. If you want, I can take pics of where the bar is at different heights?
Daniel
Old 04-01-2014, 06:14 PM   #11
Jfarns03
Jfarns03's Avatar
Oh no thanks though man, I have it on order from summitracing now. I'll make it work either way ��
Improvise, adapt, overcome ! Haha
