Old 04-22-2011, 11:19 AM   #1
djinva
djinva's Avatar
Steering Column Bearing
I am having trouble find a replacement bearing for my steering column. I feel sure some of you have had to replace it. Suggestions?
73 C-10 Cheyenne Super 454
60 Impala LS powered
16 Camaro 2SS 6speed
12 Ultra Classic
71 Vega Wagon V8 4 speed
djinva is offline   Reply With Quote
Old 04-22-2011, 11:41 AM   #2
cdowns
cdowns's Avatar
Re: Steering Column Bearing
for bearings that i cant find by specific application i go to graingers and purchase by measurements// my dust collector for blast cabinet needed a bearing only replacement from manuracturer was the whole darn motor, for about $5 withshipping i got the bearing from graingers and its back in business
Old 04-22-2011, 12:23 PM   #3
packrat42
packrat42's Avatar
I would like to know a lil about this too..
'72 Nova
'71 C10
'63 VW Beetle
...............................____
.................________-|___\____
..;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________________
packrat42 is offline   Reply With Quote
Old 04-22-2011, 12:57 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
Are you talking about the lower or the upper?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 04-22-2011, 12:58 PM   #5
70STOVEBOLT
Did a quick Google search and Brothers shows both the upper and the lower.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 04-22-2011, 01:19 PM   #6
68gmsee
Active Member
68gmsee's Avatar
As Cdowns mentoned: If you're in a hurry most bearings have a number and if you have a bearing place listed in the yellow pages take the bearing with you and see if they can match it. I have replaced several in the past that way.
68gmsee is offline   Reply With Quote
Old 04-22-2011, 04:32 PM   #7
Wrenchbender Ret
I dont think you will find these brgs at a industrial supply store. They are specific to these columns. The lower one comes with a kit that includes the spring & seat. I have the GM part numbers at the shop & can look them up tomorrow. Many of the specialty supply parts places have them.
George
Wrenchbender Ret is offline   Reply With Quote
Old 04-22-2011, 05:03 PM   #8
lakeroadster
X2.....
Classic Parts has both the upper and lower bearings: http://www.classicparts.com/Steering...oducts/307/1/0
American Classics has them too... http://www.classictruck.com/category...column+bearing
Some vendors offer a sleeve type bearing for the lower bearing. Since the steering column isn't water tight at the base, water gets in and wreaks havoc with the OEM roller bearing. I went with the sleeve bearing from American Classics, something you might want to consider.
Another thing to look at: If the lower bearing has failed the steering column shaft may be worn. On my truck it was severely worn and I welded and machined it down.
How it looked at disassembly
How it looked after repair:
Hope that helps!
John
Pictures of bearings below are:
Lower Sleeve Type Bearing, Lower Roller Type Bearing Kit, Upper Bearing (Roller Type)
lakeroadster is offline   Reply With Quote
Old 04-01-2014, 11:24 PM   #9
sambudo
sambudo's Avatar
Where do you use that lower sleeve type bearing ?
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
