I-6 250 power steering pump pulley
Hi,
I am new to the forum. I have a 66 with a I-6 250 and plan to add stock power steering. I have purchased a OEM power steering pump bracket set but need have not been able to determine the correct power steering pump pulley. If anyone knows the correct GM pump pulley number and a source your assistance will be appreciated. Thanks |
Re: I-6 250 power steering pump pulley
Hey! Welcome to the forum! I bought a bracket kit without a pulley too. I found one that worked great after a little research. I'll try to find the info on what I used. Lets see a picture of your current pulley set up for water pump/alternator and crank.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
Thanks for the response. I am out of town for the week but will take pics and post them when I return home. The set up currently on m truck should be the stock set up for a 66 with out AC or power steering.
I'm interested in knowing what you did. Imy ps pump pulley doesn't align with the other pulleys.
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
Has there been any updates???? I'm in the same boat with my I-6 pulleys
