Old 04-20-2014, 03:47 AM   #1
bh86
Alternator wiring and injectors and coils
Ok I'm swapping an 02 5.3 into my 82, I'm using a 91 suburban wiring harness and I've stripped the tbi stuff out. I'm curious if I can use the stock wires for coil, injectors, ECM 12v, ECM 12v with key, and whatever else. I'd like to avoid using an aftermarket fuse block as much as possible. Thanks for any help!
bh86 is offline   Reply With Quote
Old 04-20-2014, 07:44 AM   #2
truckdude239
truckdude239's Avatar
Re: Alternator wiring and injectors and coils
Im not understanding there is just no way the 91 harness will fit the 5.3 you can use it to feed power to the 5.3 harness. But theres nkt enough wires in the 91 harness for 8 injectors and 8 coilss
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-20-2014, 10:01 AM   #3
bh86
Yes I know that I am using it to feed the 5.3 harness is all.
Old 04-20-2014, 10:40 AM   #4
littlevictories
if there's enough room for the 2 relays (3 or 4 with electric fans) i dont see why not.
littlevictories is offline   Reply With Quote
Old 04-20-2014, 11:50 AM   #5
bh86
if im using the factory fuel relay what else do i need for a relay? I'm a lil new at this so thanks for the help!
Old 04-20-2014, 12:43 PM   #6
ls1nova71
ls1nova71's Avatar
The problem with what you're trying to do is the power from the fuse box (where the fuses you're wanting to use I assume are) is powered by the ignition switch. It won't handle the load of the LS harness. You need to run the LS harness off of an ignition relay to take the load off the switch. You could rewire the fuse box and have it powered up by the relay in the fuse locations you want to use, but it won't be easy. The fact you asked this question leads me to believe you've never done a swap like this before, so for a first time swapper, I think you'd be getting in over your head. Please don't take that the wrong way, as I don't know your skill level, just trying to help by keeping things simple.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-20-2014, 02:18 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Your trying the right ideas, just from the wrong harness. You can cut a stock LS harness DOWN to do what you want, but building the 91 harness UP just won't work out.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-20-2014, 02:54 PM   #8
truckdude239
Need to let the ls harness control the fuel pump
David fuller
2000 Tahoe 5.3l 378
Old 04-20-2014, 03:26 PM   #9
bh86
I guess I worded it wrong. I'm only looking for the power supplies to come from the 91 harness. I think I found the correct info on lt1swap's Facebook page. I'm still not sure where to run the volt gauge tho
Old 04-20-2014, 04:12 PM   #10
ls1nova71
ls1nova71's Avatar
You won't have to do anything for the volt gauge, its in the dash harness and reads voltage there. To power up the ignition relay, use the wire that originally went to the coil, it will stay hot during cranking, a lot of circuits in the fuse box will loose power while cranking. You will NEED a seperate fuse block for the engine harness though.
