Old 12-24-2013, 05:10 PM   #1
woodfork1
Looks Are Deceiving 1971 C10 LWB Rebuild
Well It time to start up the rebuild. I purchased with the intent of a simple restoration but the more and more I tore it down the more I found. Oh well!
woodfork1 is offline   Reply With Quote
Old 12-24-2013, 05:20 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Looks Are Deceiving 1971 C10 LWB Rebuild
I will be listing a huge amount of parts on the parts forum next week at rock bottom prices if it helps ? let me know what you need I think I can cover just about anything !
Old 12-24-2013, 05:27 PM   #3
hugger6933
I know the feelings I have had fender touch ups end up with total paint strippings, tune ups ending with frame off restos. Simple and quick little builds on these trucks may be a thing or the past well at least to the level I have decided upon.I have three this style 1 68, two 70's one of the 70's was gonna be the "cheaper" build of the three. It has now turned into a frame off as well with the 327 that I got with it but some engine upgrades and instead of the 3oot a T-5 from a hybrid Camaro S-10 two trans deal. I have even gone so far as to split the bedside form the inner stuctures to take care of the surface rust. things like that and it still is gonna be the "cheap"one? Oh yeah, I have a tilt column that I ground the shifter stuff off of and filled the holes primed it to paint body color to look like a factory floor shift tilt. I have a tach vac dash for it and some bucket seats with a fold down console similar to the buddy buckets but they were from a custom truck from 1993. I will have them covered to look like the seats should have from 70. and of course I will be adding power steering and brakes and disc 6 lugs still. Yeah I know what it is like when things go overboard and out of control.
hugger6933 is offline   Reply With Quote
Old 12-24-2013, 05:34 PM   #4
woodfork1
Old 12-24-2013, 05:39 PM   #5
woodfork1
I have started tackling some issues more so
than others.
Old 12-24-2013, 05:46 PM   #6
woodfork1
New Roof Skin coming.
Old 12-24-2013, 05:52 PM   #7
woodfork1
Size:  76.5 KBPrep work hasbeen done just have to install the new skin.
Old 12-24-2013, 05:55 PM   #8
Grumpy old man
OUCH ! Hope you bought it cheap ?
Old 12-24-2013, 06:04 PM   #9
woodfork1
Old 12-24-2013, 06:15 PM   #10
Grumpy old man
I'll bet that whole truck is filled with secrets and bondo ! sad when you trust someone but a shiny paint job doesn't always mean a good deal ! thats why i always buy failed projects they have little to hide !
Old 12-24-2013, 06:20 PM   #11
Grumpy old man
I'd track down the seller and get my cash back
Old 12-24-2013, 06:24 PM   #12
leddzepp
Moderator
leddzepp's Avatar
You will need to become a subscribing member to list parts for sale
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-24-2013, 06:34 PM   #13
woodfork1
This is where I'm at now. So far not so bad just time consuming.
Old 12-24-2013, 07:10 PM   #14
woodfork1
I have all new Mog suspension parts across the front, new brake calipers, brake pads, rotors, lines, McGaugay 3' drop spindles and springs and drop shocks. I've already had the upper and lower ball joints (Mog) replaced also. I will be using POR15 and a coat of chassis coat black to go on top for the frame. I want to replace the Steering gear box while torn down. are there any issues to consider for that removal and installation.
Old 12-24-2013, 07:12 PM   #15
Grumpy old man
It's only money I'll make more !
Old 12-25-2013, 01:54 AM   #16
gvw5400
gvw5400's Avatar
Rust sucks. hang in there, your roof rebuild looks good. Have fun building your truck!
All the best, Dirk and Merry Christmas.
gvw5400 is offline   Reply With Quote
Old 01-03-2014, 10:03 AM   #17
woodfork1
I got a good day of work in on it yesterday. Im ready to start putting hr back together.
Old 01-03-2014, 10:05 AM   #18
woodfork1
Two coats of POR 15 followed by a top coat of Chassis Coat Black. Came out ok.
Old 01-07-2014, 06:43 PM   #19
woodfork1
I started putting parts back together, looks like its coming along. I'm having a hard time trying to get the lower control arm bumpers in. Any suggestions.
Old 01-07-2014, 09:05 PM   #20
morgan71
Soak in boiling water until they are pliable. Also turn the upper bumpers over.
morgan71 is offline   Reply With Quote
Old 01-07-2014, 10:07 PM   #21
woodfork1
Yes I saw that right after I put them in.
Old 01-07-2014, 10:08 PM   #22
Ridgeclimber
The rubber stop on the top of the upper control arm doesn't look right. Isn't it suppose to be on the under side?
Ridgeclimber is offline   Reply With Quote
Old 01-07-2014, 10:12 PM   #23
woodfork1
It's been corrected.
Old 01-10-2014, 03:17 PM   #24
woodfork1
After doing a 2.5 drop spindle and 3in coil in the front. I placed the wheels on and now the tie rod and lower control Arm touches the inner wheel. What gives? The spindles and springs are McGaughy's and with 15 inch Rally wheels.
Old 03-04-2014, 12:47 PM   #25
woodfork1
Finally got the motor in. A little at a time.
