Old 03-07-2014, 11:48 AM   #1
boynton
boynton's Avatar
Short Bed and Cab and Ford 9" $1600
This is the perfect start for someone wanting to drag frame or extreme static drop. The bed has a steel floor and cut out wheel tubs as well as shave side markers, stake pockets and tailgate.
The cab is in fairly decent shape. It is a big window cab. It has tri plus rockers tacked in (final welding needed. Someone started to patch the floor and did not do a very clean job, but there is not much done. The cab corners need to be replaced and a little work done on the right side of the firewall. there are a few dings on the back of the cab that need to be worked.
The ford 9" comes with all the brackets (weld on trail arm brackets) needed to mount one to a 67-72 truck. I have a weld on adjustable tracking arm with new bushings. I have the Ford axels and backing plates. The rear end has been shortened, but the axels have not (you would just need buy shorter chevy axels). I have the gears (unsure the ratio, but if you tell me how to check I will).
I am working on posting pictures right now. call or text 254-541-8105 I will tell you everything I know about these items, but I did not do any of the work, I bought them as a group of parts and I am not needing these.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 03-07-2014, 11:54 AM   #2
boynton
boynton's Avatar
Re: Short Bed and Cab and Ford 9" $1600
Pictures
1970 SWB Step-Side
Old 03-07-2014, 12:01 PM   #3
boynton
boynton's Avatar
The doors in the picture are included with the cab. They are bare doors-no window regulators ect. The doors need the normal rust repair in the bottom of the doors.
1970 SWB Step-Side
Old 03-07-2014, 12:05 PM   #4
boynton
boynton's Avatar
As stated in the title the package price is $1600 OBO will separate make offer on what you want. I do want to keep each piece-rear end, bed, and cab with doors together. I do not want to sell the mounts or adjustable tracking arm separate. I would like you to pick up, but I can drop off (with in reason) to a shipping company. I am located in Salado, TX which is ext 284 on I-35 (about 45 minutes north of Austin, TX).
1970 SWB Step-Side
Old 03-08-2014, 07:01 PM   #5
boynton
boynton's Avatar
Looking to move this stuff, make me an offer.
1970 SWB Step-Side
Old 03-09-2014, 04:14 AM   #6
Jb70c10
Pm sent on bed
Jb70c10 is offline   Reply With Quote
Old 03-09-2014, 02:51 PM   #7
boynton
boynton's Avatar
Pm replied
1970 SWB Step-Side
Old 03-14-2014, 12:51 AM   #8
boynton
boynton's Avatar
$1300 obo
1970 SWB Step-Side
Old 03-15-2014, 12:52 AM   #9
boynton
boynton's Avatar
Someone please come buy this stuff...make me an offer I can't refuse!
1970 SWB Step-Side
Old 03-15-2014, 11:59 AM   #10
wiggins
wiggins's Avatar
are those doors for sale? 1972's?
Preserving American History one truck at a time.
wiggins is offline   Reply With Quote
Old 03-15-2014, 12:14 PM   #11
boynton
boynton's Avatar
Yes and no they are 67-71
1970 SWB Step-Side
Old 03-15-2014, 12:16 PM   #12
wiggins
wiggins's Avatar
ok thanks but I'm needing 72's
Old 03-19-2014, 06:16 PM   #13
boynton
boynton's Avatar
$1200 I need to clear my trailer.
1970 SWB Step-Side
Old 03-20-2014, 01:35 PM   #14
TBONE1964
Cluster King
TBONE1964's Avatar
"I have the gears (unsure the ratio, but if you tell me how to check I will)."
If you count the number of teeth on both the ring gear and the pinion gear and divide those numbers, you will have the gear ratio.
For example:
43 teeth on the ring gear
11 teeth on the pinion gear
43 / 11 = 3.90 or 3:90:1 as it is wrote.
42 / 12 = 3.50 or 3:50:1
Good luck with your sales.
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 03-21-2014, 07:15 AM   #15
blfuller123
blfuller123's Avatar
What are the dimensions and can you post pictures of the rear end?
blfuller123 is offline   Reply With Quote
Old 03-21-2014, 09:02 AM   #16
bestchevyfan
Hi, are the doors good ? Rust ? What are you asking for them ? Thanks,buddy
bestchevyfan is offline   Reply With Quote
Old 03-23-2014, 02:15 AM   #17
boynton
boynton's Avatar
Ok so I looked at the doors again and they are '72s. I had a couple of sets and got them confused. $100 for the pair. They are usable but do need some rust repair in the usual places I will try to post more pictures when I get a chance or send me a text and I will send them to you. I have been working a lot and have not had a chance to sit down at the pc and load them up. wiggins since you asked first, you get first shot.
1970 SWB Step-Side
Old 03-23-2014, 11:43 PM   #18
boynton
boynton's Avatar
I will get this info in the morning and try to post pictures asap.
1970 SWB Step-Side
Old 03-23-2014, 11:44 PM   #19
boynton
boynton's Avatar
Cab and Bed are sold Ford 9" and '72 doors are left. Make reasonable offer if interested.
1970 SWB Step-Side
Old 04-23-2014, 02:14 AM   #20
boynton
boynton's Avatar
Ford 9" measures 56 3/8 flange to flange without backing plates. The rear end is 3:73 open diff.
I thought I replied to this thread with this info but obviously not. I will try to post pictures in the am.
1970 SWB Step-Side
