Old 04-29-2014, 06:29 PM   #1
sbwillard
Smile remote doors
I have a 87 R10 with power door locks. I would like to add remotes. Anyone done this or can tell me best place to start?
THANKS!
BW
sbwillard is offline   Reply With Quote
Old 04-30-2014, 02:22 AM   #2
andrewmp6
Re: remote doors
If you can wire it yourself http://www.avsontheweb.com/product.p...cat=500&page=1 and how to http://www.avsontheweb.com/REC4_MANUAL.pdf
Old 04-30-2014, 06:22 PM   #3
nekkidhillbilly
Re: remote doors
just buy one of the kits and hook it up autoloc is one brand that makes them.
nekkidhillbilly is offline   Reply With Quote
Old 04-30-2014, 06:44 PM   #4
pontgta
pontgta's Avatar
Re: remote doors
Pretty easy.. First you get an alarm or keyless entry system. Then the alarm will determine neg trigger or pos trigger. You. Will then use relays to change the polarity if needed. When i installed mine i just got an alarm and hooked up the negative triggers for the. Door locks. I. Used in wire splices, so no cut wires. Basic info ... I know, but very hard to explain i.... I will try to find some pics.
pontgta is offline   Reply With Quote
Old 04-30-2014, 08:55 PM   #5
sbwillard
Re: remote doors
Much THANKS guys. Think I have it down.
BW
Old 05-01-2014, 02:33 AM   #6
andrewmp6
Re: remote doors
Any key less entry or alarm will do,The reason i showed you the avs one is the remote looks better then most and has a sliding cover and you can change out the buttons to anything you want.
Old 05-01-2014, 05:47 AM   #7
S10Fan
Old Heap Driver
Re: remote doors
http://www.the12volt.com/
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
