Old 05-04-2014, 05:18 AM   #1
Flthead
Power brake conversion ? Factory stock booster 1966
Have factory power brakes on a '66. Already converted to disc front can I use factory '66 booster with a '72 master cylinder an proportioning valve from the '72. Just curious if master will bolt up an work on stock booster
Flthead is offline   Reply With Quote
Old 05-04-2014, 01:19 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Power brake conversion ? Factory stock booster 1966
You should be able to use a '72 MC that was for a power brake application. Should bolt up without any issues.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-04-2014, 08:22 PM   #3
gimmy 64
i used the stock 64 booster with a 72 master for disc brakes worked good untill the booster went out
gimmy 64 is offline   Reply With Quote
Old 05-05-2014, 01:45 AM   #4
Captainfab
60-66 Nut
You will want to check to be sure that the intermediate pushrod is the correct length for the master cylinder.
