Old 05-04-2014, 08:59 PM   #1
1slo_camaro
700R swap now no Fuel gauge?
What did I do wrong??? I swapped from my th350 to a 700R4 and now all of a sudden my gas gauge reads over full at around 3 o clock. What did I pinch, diconnect break rip tear ground???? What did I do wrong? I had to call it quits for the night because of sun light but still want to see what could have possibly happened and where to look before I just crawl under and start grabbing stuff.
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 05-05-2014, 09:27 AM   #2
oilmanpat
Re: 700R swap now no Fuel gauge?
Make sure tank is grounded.
oilmanpat is offline   Reply With Quote
Old 05-05-2014, 10:02 AM   #3
1slo_camaro
How so? Like everything was fine... 2hrs later after the swap now it no worky....
Old 05-05-2014, 12:54 PM   #4
Gmc-76
Gmc-76's Avatar
Can you give some info on the swap? I currently have a th350 in my 85 c10 and I would like to have a 700r4 for the over drive and shorter first gear. Maybe make a thread for the swap?
Andrew
85 Sierra Classic c10, 305/350/2:73(86k original)
instagram: anabb_98
Gmc-76 is offline   Reply With Quote
Old 05-05-2014, 03:14 PM   #5
1slo_camaro
There are several swaps. And pull your th350 install 700r4 and gp. Mine is running with no tv cable and no lockup hooked up right now. Its a simple swap and can be done in an afternoon. I recommend doing more research into the details and items needed for the swap
Old 05-05-2014, 05:07 PM   #6
77c10
77c10's Avatar
For what it's worth...
I have been told the quickest way to ruin a 700r4 is by driving the vehicle with either no TV cable or one that is way out of adjustment.
Just my .02
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 05-05-2014, 05:11 PM   #7
1slo_camaro
I agree i just threw it in waiting to hear back if autozone has the bracket or not before i make the trip. I didnt realize my bracket wouldnt work until i put it in and my jeep isnt legal to drive yet
Old 05-06-2014, 04:07 PM   #8
1slo_camaro
Is anyone able to help out?
Old 05-06-2014, 04:20 PM   #9
SCOTI
SCOTI's Avatar
Did you check the tank grounds & wiring? You swapped trannys so possibly a wire got pinched somewhere between the tank & dash. Common for something to get pinched between the block/bellhousing during a thrash on something older.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-06-2014, 06:16 PM   #10
1slo_camaro
All that happened was the connection at the firewall got unplugged somehow. I have to get this deleted now lol
