Old 05-15-2014, 01:44 PM   #1
dtkarst
1961 Apache question
My K10 Apache hasnt ran for awhile and now when i try to start it, the vaccuum advance doesnt seem to be working. Its getting spark, but not firing and the distributer is about the only thing i can trace the problem to. So has anyone had to replace them or know how to get them to work properly again? thanks
dtkarst is offline   Reply With Quote
Old 05-15-2014, 01:53 PM   #2
paulspickupparts
Re: 1961 Apache question
Two things to get it going. If you have spark (at the plugs) check for fuel. I do not think the vacuum advance is your problem. Take off your air cleaner and see if you have fuel to your carb. Fuel and spark .
paulspickupparts is offline   Reply With Quote
Old 05-15-2014, 07:07 PM   #3
ky-donzi
Typically fuel, spark = run. If you are getting a weak spark (orange, not blue spark) then you problem is the coil, cap, rotor, ect....... My bet is your points are dirty and you are getting a weak spark... Seen it many times on cars that set
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD
73 k5 gm crate 350-265 / sm465 / np205 3.73 posi
ky-donzi is offline   Reply With Quote
