Old 05-16-2014, 01:10 AM   #1
jtrichard
Clutch hyd to linkage 63 gmc
I haven't looked yet at the pedal set up ....what will it take to go FROM hyd. clutch to linkage on a 63 GMC ... I know the obvious bell crank and bell housing ...mainly under the dash is the question .... then i can use power booster and dual brake master truck has V6 now putting V8 in..... has anyone done this? ..i tried search did not come up with much
jtrichard is offline   Reply With Quote
Old 05-16-2014, 06:08 AM   #2
Old Truck Man
Old Truck Man's Avatar
Re: Clutch hyd to linkage 63 gmc
Simply plug the line on the master cyl that goes to the Hyd cutch and it should work. I changed the clutch linkage on my 62 GMC to mechanical it required making a hole in the firewall for the release rod and welding a bracket to the frame to mount the bellcrank. Mine wasn't power brakes but I still used the same dual resevor master cyl. Just plugged the one side.
Old Truck Man is offline   Reply With Quote
Old 05-16-2014, 08:27 AM   #3
1963c-10
1963c-10's Avatar
I just removed a frame mount for the z-bar....pm sent
1964 Short bed trailer
