Old 05-28-2014, 12:31 PM   #1
G-NUT
G-NUT's Avatar
8 lug to 5 lug conversion - what do do with the rear end
I'm considering changing from a 8-lug wheel pattern to a 5-lug wheel pattern. With the front I am thinking about going with EarlyClassic.com's C20 3/4 ton to 1/2 ton spindles and getting the 5-lug rotors.
My question is what do I do with the rear end. It is an 8-lug 14 bolt rear.
The truck is a 1985 GMC Sierra Classic 2500 3/4 ton crew cab LWB. The ultimate goal is to install a PorterBuilt DropMember front and rear.
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 05-28-2014, 03:31 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 8 lug to 5 lug conversion - what do do with the rear end
You will likely need to swap out the rear end for a 5 lug 1/2 ton version. Should be tons of them available in any junk yard. Find one with the right rear end ratio that you want. Should bolt right. You might need the 1/2 ton driveshaft as well, as I think the u-joints are different then 3/4 ton.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-28-2014, 03:46 PM   #3
tinydb84
tinydb84's Avatar
They make conversion hubs but they are expensive. It would be cheaper to find a used 5 lug.
You can get conversion spacers (though there is a safety concern with that for some).
David
Instagram: myfabguy
Old 05-28-2014, 04:11 PM   #4
chevy_mike
chevy_mike's Avatar
Biggest issue is likely going to be the center hub size. 8 lug hub bore is huge compared to a 5 lug setup. I don't think you would find 5 lug wheels that would fit over the hub, unless you used an adapter that made it flush with the end of the hub.
Old 06-03-2014, 05:05 PM   #5
my67c20
The real question is why?
my67c20 is offline   Reply With Quote
Old 06-03-2014, 05:23 PM   #6
moregrip
moregrip's Avatar
http://offroad-review.com/new/index.php?page=360
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 06-03-2014, 06:23 PM   #7
chevy_mike
chevy_mike's Avatar
Originally Posted by moregrip View Post
Cool find. Great idea but at $400 for the pair, likely finding another axle is way cheaper. Other issue is the 5 lug pattern is for a 5 on 5.5 or large Ford/Jeep. Chevy would be 5 on 5. 6 lug would be fine though.
Old 06-03-2014, 08:49 PM   #8
G-NUT
G-NUT's Avatar
I am going to install a full Porterbuilt air ride suspension on it; bought it with this sole intent. I thought keeping with the 8-lug setup would help make is standout a little from other dropped C10's but the wheel selection is severely limited with the 8-lug for the sizing and fitment I'm looking for versus the 5 lug patter.
Old 06-04-2014, 12:32 PM   #9
my67c20
Answers my question.
Old 06-04-2014, 01:07 PM   #10
tinydb84
tinydb84's Avatar
There are tons of wheels for 8 lugs. Plus with a 14 bolt you can get cab and chassis hubs which narrow the rear end an extra 4 inches which allows you to run a bigger tire.
Check out these (you have to scroll down a bit to get past all the dually rims): http://4wheelonline.com/American_Force_Wheels.29008
David
Instagram: myfabguy
