Old 05-16-2014, 08:32 AM   #1
rdgt67
distributor issue?
While changing points on my 250 6cyl I noticed the edge og the distributor cap poles are burned as if that is where it's firing and not the center. Any one got an idea.?
rdgt67 is offline   Reply With Quote
Old 05-16-2014, 05:15 PM   #2
Wrenchbender Ret
Re: distributor issue?
A small amount of burning in this area is normal. If it has brass terms. they do better then the aluminum ones. If it is excessive, replace the cap.
Wrenchbender Ret is offline   Reply With Quote
Old 05-16-2014, 09:23 PM   #3
68gmsee
Active Member
68gmsee's Avatar
From your question, I assume you're thinking the timing is off. Spark (arc) occurs when the points open so check the point gap carefully and then the engine timing.
As wrenchbender says, pitting or burning of the posts is normal after years of use and cap and rotor should be replaced if you're not sure when they were replaced last. I prefer the better quality kits and usually replace everything including the condenser at the same time.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-16-2014, 09:30 PM   #4
rdgt67
I will do that first thing. I can't find the timing mark on my balancer so I have to make one. Thanks for the feedback.
Old 05-16-2014, 11:40 PM   #5
68gmsee
Active Member
68gmsee's Avatar
All balancers I've ever seen had a mark of some sort. If yours has the belt groove on it, check the edge carefully. There should be a notch on the edge.
06 Trailblazer
