Old 05-15-2014, 05:54 AM   #1
Bagged1972
Headers or exhaust manifolds
Ok guys I have a bagged 72 C10 with cupped lower control arms and 2in drop spindles so my issue here would be I tried a set of long tube headers and they are almost hitting the ground so I was wondering if y'all think a set of factory rams horn manifolds would work better for my application?
Bagged1972 is offline   Reply With Quote
Old 05-15-2014, 06:42 AM   #2
66 C10 383
Re: Headers or exhaust manifolds
What do you have motor wise? A stock 283 would have different needs than a built motor.
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 05-15-2014, 07:21 AM   #3
Bagged1972
Sorry it's a 350 with a mild cam so nothing real special
Old 05-15-2014, 07:06 AM   #4
andrewmp6
Manifolds or a pair of shortie headers will work better.
Old 05-15-2014, 07:22 AM   #5
panhandler62
Java Mechanic
panhandler62's Avatar
If you want compact *and* power you'll need to spend a bit. If you just want good looks and the raspy sound headers generate you can get a set of block huggers for under $300 (less if you don't want ceramic finish.)
If you want quality, tuned headers that tuck up tight you'll probably need Thorleys or a custom bending job.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 05-15-2014, 08:04 AM   #6
Bagged1972
Thanks for the advice I'll look into those
Old 05-15-2014, 09:10 AM   #7
bdiamond
If you don't want shorties, 2nd gen Camaro long tubes fit well on a truck in most all instances.
bdiamond is offline   Reply With Quote
Old 05-19-2014, 12:51 AM   #8
King Cary
Go with shorties... Great sound with the extra clearance...
King Cary is offline   Reply With Quote
