RAT1968 '68 Cab/'71 Parts
TH350 OOzing
There's some seepage at the shifter rod....where it goes into the body of the trans.
I went to Napa today and they ordered the "part"...$1.69. I can't find a schematic anywhere....I'm hoping that it goes in from the outside and that it's something I can do...... with my limited brains and limited patience. For a long time, I was "chasing" a brake fluid leak. Right now, there are only two fluids in the truck...oops...three including the differential. So, as I chased an elusive brake fluid, the trans fluid was fooling me. 65 and I STILL can't tell one from another. Even when brake fluid is so caustic. What the $#&^%@? Anyway, any tips on the trans shifter rod seal removal/replacement?
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
Re: TH350 OOzing
If I remember correctly on a th350, drop the pan, drive the pin out that holds the shift rod to the detent plate and slide the shaft out twoards the outside. Remove the old seal and drive the new one in with a appropriate sized socket. I also think there is a o-ring on the shaft, replace it also. All in all a easy job, good luck.
Re: TH350 OOzing
Another note, I have changed them w/o removing the shaft from the trans by just using a deep socket but getting the old seal out is more trouble than its worth and you really should change the o-ring anyway.
Re: TH350 OOzing
There is a speciality tool for replacing the selector shaft seal. Just can't think of it at the moment. Mine grew legs years ago. Here take a look at post #4 http://www.hotrodders.com/forum/th35...ll-211281.html
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: TH350 OOzing
Don't drop the pan there is a seal removal tool you can get from napa part number 776-9250. Simple job.
Re: TH350 OOzing
for sure you dont have to drop the pan there is a special seal tool i have removed them with a pick tool before though
that shifter seal is the same for many different trans good luck
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
![]() Join Date: Dec 2011
Re: TH350 OOzing
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: TH350 OOzing
I use two little screws to pull them. Take an awl or tiny pin punch and poke two holes in the old seal opposite of each other. Make sure you poke the seal only and not get too close and gouge the shaft. Then screw two little screws into the holes you made and pull upwards with dikes.
Here is a TH350 I did awhile back on my stepside. ![]() Tap the new seal in with a deep socket, a piece of conduit, or about anything that allows you to tap it in place easily. ![]()
